Hi. I can not understand why the argument of the last function "disappears" Thanks in advance Alvaro. dec2hex bad.sm (26kb) downloaded 22 time(s). dec2hex bad.pdf (208kb) downloaded 14 time(s).
The answer is in dec2bas(x,b). In the third row there is x:(x-m)/b; arguent:something inside the function is a pass-by-reference operation from the function to the argument, hence the behavior (900 becomes 0). If you don't want it, assign x to an internal variable and do all the definition operations on that variable (f.e. z:x -> z:(z-m)/b) Edited by user 24 August 2018 02:51:59(UTC)
| Reason: marked as SOLVED |
If you don't want it, assign x to an internal variable and do all the definition operations on that variable (f.e. z:x -> z:(z-m)/b) Tante grazie Davide! I did not know where else I could look for the error, because I thought I had reviewed everything. Best regards. Alvaro.
