SMath Studio Forum
Bugs & Problems
Wrong temperature conversion formulas
* The formula for converting Celsius degrees to Kelvin should be K = C + 273, instead it seems to be programmed as K = C-273
* Also, the formula for converting Fahrenheit degrees to Rankine should be R = F + 460, instead it seems to be programmed as R = F - 460
Originally Posted by: Gilberto E. Urroz * The formula for converting Celsius degrees to Kelvin should be K = C 273, instead it seems to be programmed as K = C-273
* Also, the formula for converting Fahrenheit degrees to Rankine should be R = F 460, instead it seems to be programmed as R = F - 460
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
I'm unable to reproduce, please provide an example where it doesn't works as expected. |
SMath Studio Forum
Bugs & Problems
