Was thanked: 16 time(s) in 7 post(s)
Can we have a check of plugins BEFORE we initiate installation?
It would be nice to know what is not compatible before we install so we can abort if our favorites are not supported.
I usually find out AFTER the install on the first run when it tells me the that some of my plugins are NOT compatible.
Dennis |
This issue only about beta-versions. I suggest you to disable updates to beta-version and use stable ones only. I plan to handle all plug-ins in about a week. New stable version will be released afterwards.
Andrey-
Yes, I believe that is correct that it installs without the check for Beta versions.
Looking forward to the next release.
Dennis |
