#1 Posted : 17 September 2018 00:14:14(UTC)
For this particular example, Carlos algorithm spits out in < hart beat !
Thanks again Carlos, it will surely help revamp some/many of the GenfitMinimize.
Levenberg_Marquardt_Code_CBG Copy.sm (66kb) downloaded 42 time(s).
on 27/09/2018(UTC)
Offline CBG
#2 Posted : 18 September 2018 23:24:56(UTC)
CBG
Hello Jean,
The same example of the Levenberg Marquardt Algorithm, but obtaining
the Jacobian Matrix through finite differences
Levenberg_Marquardt_Code_CBG_Jean_JMFD.sm (78kb) downloaded 29 time(s).
#3 Posted : 20 September 2018 17:23:37(UTC)
Originally Posted by: CBG Go to Quoted Post
Hello Jean,
Thanks, Carlos: works fine.
More doctoring for you !
The work sheet "Otherwise" is only slightly otherwise for convenience, works fine.
The "Jacobian Fails" is another model attempted, Jacobian complains ... Ah !
Same model Pharmacokinetics works fine Conjugate gradient Minimize.
True: some model function can only be fitted by hand
True: GenfitMinimze may be difficult to initialize but work fine for my huge
collection [about 80 projects in Smath].
Levenberg_Marquardt_Code_CBG Model Otherwise Jacobian FAILS.sm (36kb) downloaded 16 time(s).
Genfit Pharmacokinetics.sm (44kb) downloaded 20 time(s).
Levenberg_Marquardt_Code_CBG Model Otherwise.sm (54kb) downloaded 18 time(s).
on 27/09/2018(UTC)
#4 Posted : 20 September 2018 18:04:20(UTC)
Jacobian is rescued but does not finish solving
... God does not love Jacob anymore !
Levenberg_Marquardt_Code_CBG Model Otherwise Jacobian NOT calc.sm (40kb) downloaded 17 time(s).
Offline CBG
#5 Posted : 21 September 2018 05:24:19(UTC)
CBG
Hello Jean
Here is the L-M file that works with your example.
Levenberg_Marquardt_JMFD_CBG.sm (54kb) downloaded 24 time(s).
#6 Posted : 21 September 2018 22:50:22(UTC)
Hello Jean
Thanks Carlos for doctoring.
By some regrouping, timing dropped from 3.8 min down to 2.6 min.
Niece Smath document for classroom and publishing.
Genfit Pharmacokinetics L-M Copy.sm (61kb) downloaded 20 time(s).
Offline CBG
#7 Posted : 27 September 2018 00:03:04(UTC)
CBG
Hi Jean
Another example of the application of the Levenberg Marquardt algorithm,
this time with the Tesla function.
Levenberg_Marquard_Tesla_OK_CBG.sm (547kb) downloaded 20 time(s).
thanks 2 users thanked CBG for this useful post.
on 27/09/2018(UTC),  on 27/09/2018(UTC)
Similar Topics
LM Algorithm !! (Samples)
by shinavn 03/07/2019 11:03:43(UTC)
