SMath Studio Forum
Bugs & Problems
[2D plot] Issue plotting points and functions together
Hi. In the attached, can plot points and functions, but not both in the same plot. Double Integral.sm (11kb) downloaded 15 time(s).Best regards. Alvaro. Edited by moderator 21 November 2018 13:41:56(UTC)
Originally Posted by: Razonar Hi. In the attached, can plot points and functions, but not both in the same plot. The old style works otherwise. You can fill the region of integration. Cheers ... Jean Double Integral.sm (17kb) downloaded 15 time(s). Double Integral FillRegion.sm (18kb) downloaded 15 time(s).
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1126 time(s) in 723 post(s)
The behaviour of arguments in nested lists seems to be unpredictable, at least I don't see the rule. Thus, re-arranging objects works but I don't know why. Double%20Integral_Kr.sm (12kb) downloaded 15 time(s). |
Hi Martin. Thanks for the tip. I guess that I take this form, from you suggestion: Best regards. Alvaro.
Originally Posted by: Razonar Hi Martin. Thanks for the tip. I guess that I take this form, from you suggestion: ... personally: I prefer the more conventional form. The example in view may fail in other instance(s). 3 in one: functions, solutions, fill-in region. X_Y Plot wisely [Solve] Boundary.sm (40kb) downloaded 20 time(s).
SMath Studio Forum
Bugs & Problems
