Absolutely Gorgeous software, which can be a level riser for spreadsheet calculation, seamlessly extended for any kind of mathematical application.
more...
by Shiju VT
This fantastic free alternative to Mathcad is going from strength to strength and I am really enjoying watching its progress. Andrey has produced something that is genuinely useful, multiplatform, fun to use and, most importantly of all, he listens to his users. Well worth a download.
more...
by Mike Croucher
Es excelente, me resulta más eficiente si la comparamos con las herramientas que se le parecen
more...
by Carlos Daniel Encarnación Zúñiga
Please note: - There are some known bugs with Worksheet scrolling - will be addressed soon;
- There are some UI issues on environment with high DPI (some Custom plug-ins may not be scaled correctly).
Please use the following to disable high dpi support if required:
To all developers: As you may notice starting from build 0.99.6955 SMath Studio supports high DPI and in order to scale Regions correctly we have to introduce new requirement: - Plug-in must use SMath.Drawing.Graphics instead of System.Drawing.Graphics everywhere.or - All Fonts created by the plug-in must have GraphicsUnit.Pixel specified as a unit and size must be multiplied by 96f / 72f in order to convert Points to Pixels.All existing plug-ins should be updated according to this requirement as everything looks ok while system is configured to have use 96 DPI, but in all other cases scaling of Fonts in plug-ins is incorrect. All modern platforms like iOS, Android, UWP have Pixel specified as a unit by default, so this issue appears on Windows machines only (we have it on Linux as well because of Mono). Please let me know in case of any related questions. If you are not able to perform changes by yourself - just let me know and I will update plug-ins by myself. Best regards, Andrey Ivashov.
on 17/01/2019(UTC), on 17/01/2019(UTC), on 17/01/2019(UTC), on 18/01/2019(UTC), on 18/01/2019(UTC)
