#1 Posted : 26 February 2019 04:02:56(UTC)
This document, freshly brewed, is a recast of the Genfit Procedure.
Now the fitted coefficients result from β:=Minimize(init,iter)
1. compose the model
2. assign the vector gradient
3. β:=Minimize(init,iter) ... done
The 3 examples are 1/1 MCD 11 except that "iter" is not automated.
By setting "iter" high enough that will worth automated.
The setup is identical to MCD where Minerr is applied to SSE from
the solve block Given/Minerr [CG, QN, LM options]
Genfit algo [init, iter] UFO Copy.sm (107kb) downloaded 41 time(s).
#2 Posted : 26 February 2019 22:35:46(UTC)
... refreshed for better publishing:
all respective modules collapsed in utilities.
This is a new example.
Genfit [HV_WEZ].sm (46kb) downloaded 19 time(s).
#3 Posted : 05 March 2019 01:36:58(UTC)
... Frame work guide line, minimalist tool box.
Genfit Pharmacokinetics al_nleqsolve.sm (29kb) downloaded 14 time(s).
Genfit [Algo Minimize(Cholesky)].sm (15kb) downloaded 15 time(s).
GenfitMatrix Copy Master ToolBox.sm (60kb) downloaded 14 time(s).
Genfit Pharmacokinetics L-M {ShortVersion] Copy.sm (102kb) downloaded 15 time(s).
#4 Posted : 05 March 2019 05:24:06(UTC)
... original L-M c/w solution Table
Genfit Pharmacokinetics L-M Copy.sm (115kb) downloaded 25 time(s).
Guest (2)
