Joined: 20/03/2019(UTC) Posts: 73 Location: Mandeville, LA
I am having problems with a specific calculation. I have a sheet that has the following on it: The answer for C is wrong. If I put it in a separate file on a sheet, the number comes out correctly as 4720 fps. Can you help?
Hi. Hope that this helps: As I know, the speed of the sound into a fluid is sqrt(K/rho)=14.9245 ft/sec, for your data and where K is the fluid bulk modulus and rho the fluid density. With your rho, in lbm/ft^3, this is the fluid density. You need g only if you have the specific weight gamma = rho/g. I know that a lot of books use rho for both: density and specific weight, and it's very confusing that notation. Best regards. Alvaro. Edited by user 29 March 2019 07:31:47(UTC)
| Reason: Correct the bulk modulus for water.
Originally Posted by: Britt1 I am having problems with a specific calculation You are asking the volunteers to remake the document. On the other hand, working with fluids, the source information(s) is required.
Sorry all, when I was looking at this, it was at the end of the day, and I was dead tired. I used the wrong number for the bulk modulus of water. All is fine. Edited by moderator 29 March 2019 17:15:41(UTC)
| Reason: marked as solved
