Hello I'm new in Smath I want to do "if δ>0 then k=a+b else k=c+d" But impossible to include the equation k:=a+b in the "if statement" When I type "equal" after "k", the "equal" sign is put on the fist line and answer "k-not defined" I found an exemple on the forum but I'm not able to reproduce it by myself My test file is attached Thank you for your help test if statement.sm (6kb) downloaded 17 time(s).
you have to type ":" (colon) and not "=" (equal) sergio Edited by moderator 29 March 2019 17:18:56(UTC)
| Reason: marked as solved
Originally Posted by: jbv Thank you for your help
