SMath Studio Forum
Bugs & Problems
Bug - Examples - Properties of generic Polygons
Hi Davide, hoping to get some help on you very old example. I have successfully used it to generate the vast multitude of shapes, the functions of which you kindly shared with us. As of late many of the shapes return an error, the source of which is not obvious. function "roundedRect(2,4,1,0)" is a good example since its simple and yet does not return expected value. Let me know if you have any thoughts on this. Best Alex M PolyProperties.sm (940kb) downloaded 34 time(s).
Thank you Alex... at first glance seems a problem about if statements not evaluated and stack. |
Fixed in the latest beta. Thank you! Edited by moderator 01 July 2019 01:19:38(UTC)
| Reason: marked as Solved
on 08/05/2019(UTC), on 01/07/2019(UTC)
Originally Posted by: Alex M. Hi Davide, hoping to get some help on you very old example. I have successfully used it to generate the vast multitude of shapes, the functions of which you kindly shared with us. As of late many of the shapes return an error, the source of which is not obvious. function "roundedRect(2,4,1,0)" is a good example since its simple and yet does not return expected value.
Hello Alex, just for my own curiosity: Does it work as well for open polygon ? Jean Maths Polygon Alex test.sm (15kb) downloaded 30 time(s).
Originally Posted by: Andrey Ivashov Fixed in the latest beta. Thank you! Thank you very much - I used this code in some crucial "programs"
Originally Posted by: Jean Giraud Originally Posted by: Alex M. Hi Davide, hoping to get some help on you very old example. I have successfully used it to generate the vast multitude of shapes, the functions of which you kindly shared with us. As of late many of the shapes return an error, the source of which is not obvious. function "roundedRect(2,4,1,0)" is a good example since its simple and yet does not return expected value.
Hello Alex, just for my own curiosity: Does it work as well for open polygon ? Jean Maths Polygon Alex test.sm (15kb) downloaded 30 time(s). Unsure what you mean, Jean?
Originally Posted by: Jean Giraud Does it work as well for open polygon ? Nope, this worksheet was made just for closed polygons. |
SMath Studio Forum
Bugs & Problems
