Joined: 20/03/2019(UTC) Posts: 73 Location: Mandeville, LA
I can't type what i want. I try and type. And it wants to put the paranthesis in the wrong spot, or something else goes wrong. I got the first line correct once, with an extra tick for input, but as soon as I went to the second line, SMath took out what I typed in the first line. Edited by user 03 May 2019 16:56:39(UTC)
Originally Posted by: Britt1 I can't type what i want. I try and type.<a href="/forum/resource.ashx?a=30834 Would help you read the Smath general user handbook.
I am reading the manual. I am going through page by page. In the below, I understood everything before this point, but I cannot type what the example says: what comes out, no matter what I type is solve(x-1):=. I can't figure our how to put anything else in the parentheses.
Originally Posted by: Britt1 what comes out, no matter what I type is solve(x-1):=. I can't figure our how to put anything else in the parentheses. Open a new document to clear previous possible "shadow in context". solve(2), solve(4) from f(x) menu ... click.
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
Originally Posted by: Britt1 ... what comes out, no matter what I type is solve(x-1):=. I can't figure our how to put anything else in the parentheses. Hi. Isn't "solve(...):=". It is "solve(...)=". Also, if you can't type "solve(x-1,x)=" try "solve(x-1;x)=" Maybe your list separator is ";" instead ",". Best regards. Alvaro.
Originally Posted by: Razonar Originally Posted by: Britt1 ... what comes out, no matter what I type is solve(x-1):=. I can't figure our how to put anything else in the parentheses. Hi. Isn't "solve(...):=". It is "solve(...)=". Also, if you can't type "solve(x-1,x)=" try "solve(x-1;x)=" Maybe your list separator is ";" instead ",". Best regards. Alvaro. Sorry. You didn't understand what I said. If I type anything in that format, SMath automatically puts in the ":" I type "solve(...)=" with the keys, but SMath forces it to come out as "solve(...):="
Originally Posted by: Britt1 Sorry. You didn't understand what I said. If I type anything in that format, SMath automatically puts in the ":" I type "solve(...)=" with the keys, but SMath forces it to come out as "solve(...):=" Maybe it's time to read more the Smath user guide book, as well as get a keyboard that works to reproduce the examples. solve(2) from the f(x) menu ... just click and fill-in.
Originally Posted by: Jean Giraud Originally Posted by: Britt1 Sorry. You didn't understand what I said. If I type anything in that format, SMath automatically puts in the ":" I type "solve(...)=" with the keys, but SMath forces it to come out as "solve(...):=" Maybe it's time to read more the Smath user guide book, as well as get a keyboard that works to reproduce the examples. solve(2) from the f(x) menu ... just click and fill-in. Not sure you read everything. I will try and explain better. I am on page 38 of the "introduction to SMath manual" and am going through it page by page. I got to page 38 and tried to type the "solve" function and the above is the problem I am having. I was trying to type and learn from the example. I understood everything before that point, and everything else is working. What I am trying to type is right from the SMath manual. I attached the file in a post above from 4 days ago. It says "Examples using both symbolic and numeric results are shown below." You say use the solve(2) function. The example does not mention that function. Do I need that function for this example?
Originally Posted by: Jean Giraud solve(2) from the f(x) menu ... just click and fill-in. Do you have the f(x) in the top menu bar ? Click f(x) ... scroll down to see solve(2) If so go by the example ... at least try.
Originally Posted by: Britt1 The example does not mention that function. Do I need that function for this example? For sure you need that function ! Go again this example.
type solve left parentheses ... cursor in parentheses then coma coma coma
I think what Britt1 is trying to ask is about the argument in the solve(2) and solve(4) function. The equal sign "=" inside the argument is a boolean. So, you'll need to use "Ctrl+=" to solve this problem. I was having some issues in other equations with the same problem, but now it's kind of working. Depends on the equation and mainly the syntax.
