Joined: 12/02/2018(UTC) Posts: 62 Location: Belém Was thanked: 7 time(s) in 6 post(s)
Hi, everyone! I'll clarify my question with an example. Let's say I create a radio button list to set the geometry of a cross-section to be Rectangular or Circular. If I choose Circular, I only have to inform (via slider) it's diameter. If I choose Rectangular, I have to inform a width and a depth. In the latter, is it possible to set the creation of the second slider dependent on my radio button input? Thanks in advance! Edited by user 09 May 2019 01:58:47(UTC)
Slider is not much convenient compared to MCD 11. SS slider had no use for me, not profitable in real projects.
... as you can see: up/dn counter and slider don't save settings. They freak themselves like dog chasing tail. IMHO: useless except for demo.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Originally Posted by: Jean Giraud ... as you can see: up/dn counter and slider don't save settings. They have, both from canvas and from dialog. So yes, it is possible to elaboratesome degree of automation based on the inputs. If the roads are too different probably would be better to use collapsed areas with backed layouts however. |
Originally Posted by: joaobr If I choose Rectangular, I have to inform a width and a depth. ... add odd/even/shaped polygons.
