SMath Studio Forum
Questions
Taking "abs" of complex vector
Joined: 02/09/2018(UTC) Posts: 3 Location: Новосибирск
Hello! Task: I have vector with complex numbers. There are need to take a vector with modules of this complex numbers. To solve this I use operators 'for' and 'abs'. You can see it in the pic below. Problem: How can you see, 'abs' not works. Question: What I do wrong? If it bug of Smath Studio, how can i workaround it? abs_vector.sm (6kb) downloaded 16 time(s).
Strange. It does work for me. Regards, Radovan |
Thanks. My version: Code:appVersion(3)="0.99.7030"
Where to download 0.99.7067 ?
Originally Posted by: Shamrel Thanks. My version: Code:appVersion(3)="0.99.7030"
Where to download 0.99.7067 ? It seems that the most recent Nightly builds are not downloadable from the Download section of the Forum. It should update from within SMath by Help->Check For Updates. I think that you should also have unchecked the Exclude beta-versions from the Extension Manager. Regards, Radovan |
Thanks! Install the update. It worked.
Originally Posted by: Shamrel Thanks! Install the update. It worked.
SMath Studio Forum
Questions
