Hi.
I have been trying to plot some data in XY plot region and it plots ok.
But formatting isn't possible. And I right-click->"Format", the windows is hidden somehow (i guess) or the Smath freezes.
Is anyone with the same issue?
Thanks.
Try to press [Alt]+[Space] and then move Format dialog to make it visible. |
This may happen if View -> Always on top is enabled.
Originally Posted by: Andrey Ivashov This may happen if View -> Always on top is enabled. I see. In my case it was unabled. But it happened because i work with 2 screens. Thanks for the tip
