SMath Studio Forum
Questions
Force input as "description content" instead of "function"
Hi Gurus: Is there a way to force the input to be "content" instead of function? Thank you! Chris
various methods: 1) "Analysis 2) from the menu: Insert -> text Region 3) Write Analysis followed by space (then you can also cancel the space)
Originally Posted by: PompelmoTell various methods: 1) "Analysis 2) from the menu: Insert -> text Region 3) Write Analysis followed by space (then you can also cancel the space)
sergio Thank you Sergio! Have a wonderful one!
Originally Posted by: aviateCar Is there a way to force the input to be "content" instead of function? By default, alpha characters is maths as you space it converts to text Shift +" opens the default text region
Originally Posted by: Jean Giraud Originally Posted by: aviateCar Is there a way to force the input to be "content" instead of function? By default, alpha characters is maths as you space it converts to text Shift +" opens the default text region Thanks for the explanation! Have a great long weekend!
SMath Studio Forum
Questions
