SMath Studio Forum
Questions
Configuration management of SMath studios and worksheets
Joined: 15/05/2016(UTC) Posts: 22 Location: Daejeon Was thanked: 1 time(s) in 1 post(s)
I have made many worksheets with severla SMath studio mono versions and specific plugins. My problem is some of the plugins (Excel I/O etc.) are not supported and I got the some of errors during my opening the old worksheets. I've downloaded old archived SMath studio version, and tried again but failed.
How could I freeze the SMath studio program, plugins and their worksheets?
Thank you for your kind help.
Best regards,
MS
You can use portable versions. Then all extensions are stored in the installation directory and you can have multiple smath installations side by side just having them in separate directories. Essentially you have to create an empty file with name "portable.version" in the installation directory before downloading any extensions. |
Thank you for the tip. Are the The portable versions SMath mono versions? All of my old mono versions archived could not plugin the "Excel I/O with recalculation and PNG" in these day. I have no idea how to solve this problem.
M.S.
Joined: 23/03/2016(UTC) Posts: 278 Was thanked: 91 time(s) in 57 post(s)
I don't think this plugin is still actively maintained. It may not work with recent versions of SMath. |
You can try this version. Just replace the ExcelIOCom.dll file. ExcelIOCom.7109.zip (10kb) downloaded 11 time(s).EDIT. I added this plugin to the gallery. Previously, it was not there, because it is very old. Unfortunately, this plugin will not work in Linux, as based on COM. Edited by user 06 August 2019 13:01:16(UTC)
I made a mistake in the type of plugin. Now I understood what was meant. I will try to update this plugin as well. |
SMath Studio Forum
Questions
