SMath Studio Forum
Questions
simple integrals give give difficult results
Integrating the simple functions 1/x, 1/x², 1/x³ upwards from 1 give correct results for low values of the upper limit but with the upper limit in the order of 200 or higher the results are not what I would expect. Please see the attached worksheet. Is there a problem with the integral function or is there something I haven't grasped? H integral.sm (6kb) downloaded 15 time(s).Edited by user 12 August 2019 22:55:34(UTC)
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 830 time(s) in 526 post(s)
Hi. It's because the integral it's a numerical procedure, and maybe not a very robust one. So, like any numerical method, if it don't work, just use another. integral.sm (14kb) downloaded 17 time(s).Best regards. Alvaro.
Hakelm, I opened your file and the results were correct. Therefore I believe that the parameter for the accuracy of the integrals in your SMath installation is not correctly set. Try to change Tools->Options->Calculation->Integral Accuracy For example, write 1000 However, Alvaro's considerations must be kept in mind sergio Edited by user 13 August 2019 12:53:24(UTC)
Many thanks for two very good answers! Now I know that Smath doesn't know even the simplest of integrals but that approximation accuracy can be improved upon. Even if I understand my system doesn't (SMathStudioDesktop.0_99_7109.Mono on Ubuntu 16.04). It can't find the function Rkadapt. I guess that the Runge-Kutta functions are to be found i some plugin. Where can I find that? H
Originally Posted by: hakelm I guess that the Runge-Kutta functions are to be found i some plugin. Where can I find that? ODE Solvers. |
Originally Posted by: hakelm Is there a problem with the integral function or is there something I haven't grasped? The Simpson integrator ranges from exact to freak. In your examples, increase the integral accuracy from menu, options, calculations, integral accuracy [max 10000] Wise to sanity Wolfram Alpha cost is 0.00 $ integral.sm (47kb) downloaded 12 time(s).
May I assume that the SMath-integral is made using Simpson's rule and that the integral accuracy [max 10000] is the number of steps taken by Simpson? H
Originally Posted by: hakelm May I assume that the SMath-integral is made using Simpson's rule and that the integral accuracy [max 10000] is the number of steps taken by Simpson? Quite right: The Smath integrator is Simpson. Ranged accuracy [50 ... 10000]. Trivial cases are exact. Two more exact cases are know 1/x [ln(x), b_spline]. On long range of the variate 'x' the Simpson/Romberg kernel gives a much better result than simple Simpson. Carlos adaptive algorithm is fool proof all cases.You want these two proposed ... reply YES/NO. Jean
SMath Studio Forum
Questions
