SMath Studio Forum
Questions
Iterative plotting for drawing a mesh
Originally Posted by: jb_bairoletto Have a look to this. I am loading the same file in two differente versions of Smath (last version and last beta). XYPlotRegion updated. Try now. |
Joined: 02/09/2019(UTC) Posts: 13 Was thanked: 1 time(s) in 1 post(s)
Hi!!! Thank you for the dedicated help!! I am attaching a real output (from a real calculation). Another thing is that rods should be placed from outside to inside (first from vertices, second in primeter and the in the interior of the mesh). I think that could be too complex! Calculo PAT IEEE-80-2000 R10 dibujo.sm (56kb) downloaded 12 time(s).
Originally Posted by: uni XYPlotRegion updated. Try now. ... from native SS6179
Originally Posted by: jb_bairoletto Another thing is that rods should be placed from outside to inside (first from vertices, second in perimeter and the in the interior of the mesh). I think that could be too complex!
I quite not understand Attached doctored version. Calculo PAT IEEE-80-2000 R10 dibujo.sm (54kb) downloaded 8 time(s).
Two things... 1) Right, seem to produce an error, but in version 7030, works... (E pur si muove!! hehehe) 2) The way the rods must be placed, is from perimeter to the center of the mesh (not in a random way). So, the first 4 rods should be places in the 4 vertices of the mesh. The fifth rod must be in middle of a side (any one). The sixth, in the middle of other side, and so on until complete all the perimeter crosses (or Tees). After that, the rods must be dran in the inner rectangel (counting from the perimeter to the center of the mes), and in the same way as before, the rods will be completing this internal perimeter. (I dont know if I make mysel clear... )
Originally Posted by: jb_bairoletto I don't know if I make myself clear In some way yes, but looks involved. IEEE-80 is over-killed by protection dogs from pissing on the fence. What about two bison fighting for MaMa ? Or deer jumping 10 ft high fence ... more ? Cheers ... Jean Fence.sm (24kb) downloaded 9 time(s).
IEEE-80 shows metallic main ground conductor. What about termites ? In their French colonial Africa, they soon learned metallic installations lasted few moons, only. Maybe , there are ways to automate the demo. Fence.sm (30kb) downloaded 7 time(s).
Originally Posted by: Jean Giraud Maybe , there are ways to automate the demo. ... you can have as many sub-squares as you wish, manually. The interlacing to show the grid lines to center, they are purely figurative/implicit, not really needed. Only one set of interlace is needed, not offered. Cheers ... Jean Fence.sm (46kb) downloaded 7 time(s).
Originally Posted by: Jean Giraud Only one set of interlace is needed, not offered. ... radial rod lines added ... pretty messy ! Fence.sm (55kb) downloaded 6 time(s).
... all radial added. Fence.sm (55kb) downloaded 11 time(s).
... multiple scaled perimeters c/w radial grids. Fence_Radial.sm (16kb) downloaded 9 time(s).
Try this [2n] for a beautiful 4 branches star. Fence_Radial.sm (18kb) downloaded 6 time(s).
Originally Posted by: Jean Giraud ... random added on outer fence. You can have random for more/all inner fences. You may have to strip for multiplicate(s) random. Anything useful in there ? Cheers ... Jean
Previous attachment deleted, Strip(,) was not correct. Fence_Radial.sm (35kb) downloaded 9 time(s).
Originally Posted by: jb_bairoletto 2) The way the rods must be placed, is from perimeter to the center of the mesh (not in a random way). So, the first 4 rods should be places in the 4 vertices of the mesh. The fifth rod must be in middle of a side (any one). The sixth, in the middle of other side, and so on until complete all the perimeter crosses (or Tees).
After that, the rods must be drawn in the inner rectangle (counting from the perimeter to the center of the mes), and in the same way as before, the rods will be completing this internal perimeter. No problem for sequence square construct ... more work rectangle. I guess that concerns the physical steps in-situ [construction crew]. Once physical installation is complete ... same plotting canvas. Maybe, I understand not enough in there. The sequence demo may be automated. Please read the two attachments. Cheers ... Jean Project Square Radial Canvas.sm (51kb) downloaded 7 time(s). Project Square Rectangular Canvas [Satellites].sm (299kb) downloaded 7 time(s).
To make myself more clear, look a this final 3D approach with 4 rods in vertices. The final plot could be something like that. This represent a mesh of "conductors/buried cables" (square or rectangular) and 4 rods stuck in the ground. Right know I am only experimenting ploting in 2D, with cables (represented as vectors) and rods (represented as points).
Originally Posted by: jb_bairoletto Right know I am only experimenting plotting in 2D, with cables (represented as vectors) and rods (represented as points). You can have the grid bed as 3D plotted as 2D, c/w 4 degrees of rotation. But can't have legs. Your CAD drawing is pure visual, has nothing to do with the maths suite wrt IEEE-80 Smath is an advanced CAS ... not at all a CAD. Finish the CAD drawing, capture as an image, paste in Smath document. Once rotated, it may be possible to add legs in the attached. Cheers ... Jean Project Square Rectangular Canvas [Rotate Fied].sm (31kb) downloaded 10 time(s).
SMath Studio Forum
Questions
