SMath Studio Forum
Samples
Advantage of vectorize function
On the request of a fellow Engineer, the attached SM program was developed to find the Standardized Precipitation Index (SPI). 58 years of daily precipitation data was available. The SPI is widely used to analyze meteorological drought on a range of time scales. There are proprietary software packages for this purpose. The “vectorize” function was pretty handy and fast in analyzing various conditions. SPI_cal-Rev & Improved-Final.sm (1,968kb) downloaded 116 time(s). Rainfal_Data.xlsx (487kb) downloaded 82 time(s).Edited by user 06 July 2019 09:02:29(UTC)
3 users thanked ndtma for this useful post.
on 06/07/2019(UTC), on 06/07/2019(UTC), on 06/07/2019(UTC)
Attached file may be useful in handling data, where it may be necessary to extract numerical values removing any strings, or negative values, zeros etc. Data Analysis Using Truth Table.sm (79kb) downloaded 48 time(s).Edited by user 19 September 2019 18:26:27(UTC)
Advantage of vectorize function revisited. Another practical example attached, with extensive use of the vectorize function. No loops used. Comments by Martin, Jean, Razonar and others on this subject much appreciated. Hope this may be useful for beginners. Cheers SPI_cal-Millawana_Multiple_R5.sm (179kb) downloaded 44 time(s). rainfall_KalaOyaBAsin.xlsx (586kb) downloaded 29 time(s).Edited by user 13 April 2020 19:23:18(UTC)
Originally Posted by: ndtma Comments by Martin, Jean, Razonar and others on this subject much appreciated.
Sorry mon Ami ... SS 6179 does not open ... Jean
2 users thanked ndtma for this useful post.
on 14/04/2020(UTC), on 14/04/2020(UTC)
Thanks for the *.PDF ... superb quality !
I have found this useful in day to day work. Data imported from MS Excel sheet, and using "findrows" function to sum daily data to monthly totals. Edited by user 12 November 2020 10:29:53(UTC)
1 user thanked ndtma for this useful post.
Attached is a simplified version of a project work for demonstration only. The data file consists of date strings, and hence, had to be transformed into numeric. Hope this may be useful for beginners. Vectorize function very useful in this exercise. Handling DATE STRINGS.sm (17kb) downloaded 26 time(s).Edited by user 16 November 2020 20:23:55(UTC)
The secret is inside your nice piece of work ... superb, thanks. Take care my Friend ... Jean
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 833 time(s) in 527 post(s)
Originally Posted by: ndtma Attached is a simplified version of a project work for demonstration only. The data file consists of date strings, and hence, had to be transformed into numeric. Hope this may be useful for beginners. Vectorize function very useful in this exercise.
Hi. Handling data strings you have also this cheat for convert dates to numeric matrices. Handling DATE STRINGS.sm (21kb) downloaded 25 time(s).Best regards. Alvaro.
on 17/11/2020(UTC), on 18/11/2020(UTC)
Thank you Jean for your kind words and encouragements. Take care.
Thank you Razonar for the superb alternative. Take care. |
You too Alvaro: take care, thanks ... Jean
Originally Posted by: ndtma Attached is a simplified version of a project work for demonstration only. The data file consists of date strings, and hence, had to be transformed into numeric. Hope this may be useful for beginners. Vectorize function very useful in this exercise. Revised program to handle date strings. Handling DATE STRINGS+Alvaro.sm (44kb) downloaded 20 time(s). |
Originally Posted by: ndtma Revised program to handle date strings.
Thanks Collab for that most useful work. Saved ... for future use. Cheers ... Jean
Originally Posted by: ndtma Attached is a simplified version of a project work for demonstration only. Hi Amarasekera. Yes, that one, thanks. The fact you're showing despite to me about the speed in procedures with arrays. In the attached some comments about the need to redefining M:=M where M is a matrix argument in a procedure. EvalTest.sm (18kb) downloaded 19 time(s). EvalTest.pdf (74kb) downloaded 11 time(s).Best regards. Alvaro.
Your last Speedy Gonzalez is the Smath Numerical Fairy. As it looks, pure numerical code coincidence as a fact. Slightly adapted for convenience SS 6179 Thanks, cheers ... Jean Maths eval(,) TEST.sm (17kb) downloaded 20 time(s).
Originally Posted by: Razonar Hi Amarasekera. Yes, that one, thanks. The fact you're showing despite to me about the speed in procedures with arrays. In the attached some comments about the need to redefining M:=M where M is a matrix argument in a procedure. Best regards. Alvaro. Alvaro, Are you showing that by redefining Mo variable, within the program, it speeds it up 30 fold? That makes no sense The only thing that remotely comes to mind is that M, being defined within the program structure as M:=Mo, is not having to read for the variable from the outside. Have you, or anyone else, tried this on other programs?
Originally Posted by: ElSid Alvaro, Are you showing that by redefining Mo variable, within the program, it speeds it up 30 fold? That makes no sense Yes. Please, try to check in your environment if this is true also. (Notice that my laptop is very slow, because always is running something else or overloaded by some other procedures) Originally Posted by: ElSid Have you, or anyone else, tried this on other programs?
Yes. For this was the issue in the original Amarasekera work, and why I say that he was the first showing this behavior. But I have other codes where using M:=M speed up slow procedures. Actually anything with a loop over a matrix. Here intermediate timing result, which I can't explain Best regards.
Originally Posted by: ElSid The only thing that remotely comes to mind is that M, being defined within the program structure as M:=Mo, is not having to read for the variable from the outside. Have you, or anyone else, tried this on other programs? What's wrong or incorrect in there is length it shouldn't exist in Smath
SMath Studio Forum
Samples
