They talk about us
I really like it. It's one of the most usable free software applications I deal with.
more...
by Juanma Belda
Great software. Excellent tool for engineering students to make study of complicated problems a breeze. Time need to familiarize is very less as there are good guides prepared for easy use.
more...
by Razook
excelente programita lo recomiendo
more...
by malandro
on 22/09/2019(UTC), on 22/09/2019(UTC), on 22/09/2019(UTC), on 22/09/2019(UTC), on 23/09/2019(UTC)
So here is the long waited gui embedded font alteration options. Thank you Andrey. Problem for me is I can't change font, bold, italic or underline options. Toolbar is there but not working. Windows 10 Pro x64 v1903 if it helps. And a suggestion, the font selection should be with searchable combobox. Regards *sorry, I had tried to change font outside of the text region. This is not possible for now I guess. I figured out you had to be inside the text region and select the text to alterate the font, obviously. Edited by user 22 September 2019 10:34:25(UTC)
I get a (recoverable) soft crash when browsing fonts with the font selector widget. The preview of some fonts is empty in the dropdown list. (Font doesn't support style regular) For usability I'd recommend to expose just a small subset of the fonts in the selector (say arial, roman and courier) and leave further options to the context menu or some expert mode. Also, I recommend to set arial as default font of text widgets (as in Writer plugin). I guess we will see the option to apply attributes to selected text instead of the whole region soon.
Informationen über das Aufrufen von JIT-Debuggen anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext ************** System.ArgumentException: Die Schriftart Brush Script MT unterstützt den Schnitt Regular nicht. bei System.Drawing.Font.CreateNativeFont() bei System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont) bei System.Drawing.Font..ctor(String familyName, Single emSize) bei SMath.UI.Desktop.MainForm.<>c.(Object , DrawItemEventArgs ) bei System.Windows.Forms.ComboBox.OnDrawItem(DrawItemEventArgs e) bei System.Windows.Forms.ComboBox.WmReflectDrawItem(Message& m) bei System.Windows.Forms.ComboBox.WndProc(Message& m) bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys ************** mscorlib Assembly-Version: 4.0.0.0. Win32-Version: 4.7.2117.0 built by: NET47REL1LAST. CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll.
SMathStudio_Desktop Assembly-Version: 0.99.7204.3920. Win32-Version: 1.1.29.0. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMathStudio_Desktop.exe.
System.Windows.Forms Assembly-Version: 4.0.0.0. Win32-Version: 4.7.2117.0 built by: NET47REL1LAST. CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System Assembly-Version: 4.0.0.0. Win32-Version: 4.7.2117.0 built by: NET47REL1LAST. CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Drawing Assembly-Version: 4.0.0.0. Win32-Version: 4.7.2117.0 built by: NET47REL1LAST. CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
SMath.Manager Assembly-Version: 0.99.7204.3854. Win32-Version: 0.99.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Manager.DLL.
SMath.Environment Assembly-Version: 0.99.7204.3854. Win32-Version: 0.99.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Environment.DLL.
SMath.Drawing Assembly-Version: 0.99.7204.3854. Win32-Version: 0.99.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Drawing.DLL.
System.Configuration Assembly-Version: 4.0.0.0. Win32-Version: 4.7.2053.0 built by: NET47REL1. CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
System.Core Assembly-Version: 4.0.0.0. Win32-Version: 4.7.2117.0 built by: NET47REL1LAST. CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
System.Xml Assembly-Version: 4.0.0.0. Win32-Version: 4.7.2117.0 built by: NET47REL1LAST. CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
SMath.Controls Assembly-Version: 0.99.7204.3854. Win32-Version: 0.99.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Controls.DLL.
SMath.Math.Symbolic Assembly-Version: 1.35.7204.3854. Win32-Version: 1.35.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Math.Symbolic.DLL.
SMath.Math.Numeric Assembly-Version: 1.67.7204.3854. Win32-Version: 1.67.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.Math.Numeric.DLL.
SpecialFunctions Assembly-Version: 1.12.7204.3854. Win32-Version: 1.12.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/SpecialFunctions.dll.
HTMLFileType Assembly-Version: 1.14.7204.3854. Win32-Version: 1.14.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/HTMLFileType.dll.
ImageFileType Assembly-Version: 1.11.7204.3854. Win32-Version: 1.11.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/ImageFileType.dll.
PictureRegion Assembly-Version: 1.10.7204.3854. Win32-Version: 1.10.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/PictureRegion.dll.
PlotRegion Assembly-Version: 1.11.7204.3854. Win32-Version: 1.11.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/PlotRegion.dll.
SMathFileType Assembly-Version: 1.11.7204.3854. Win32-Version: 1.11.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/SMathFileType.dll.
StandardToolboxButtons Assembly-Version: 1.1.7204.3854. Win32-Version: 1.1.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/StandardToolboxButtons.dll.
TextRegion Assembly-Version: 1.11.7204.3854. Win32-Version: 1.11.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/TextRegion.dll.
ViewerFileType Assembly-Version: 1.1.7204.3897. Win32-Version: 1.1.7204.3897. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/ViewerFileType.dll.
XMCDFileType Assembly-Version: 1.12.7204.3854. Win32-Version: 1.12.7204.3854. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/plugins/XMCDFileType.dll.
SMath.UI Assembly-Version: 0.99.7204.3897. Win32-Version: 0.99.7204.3897. CodeBase: file:///C:/FHB/Software/SMath/SMath%2099.7204/SMath.UI.DLL.
System.Windows.Forms.resources Assembly-Version: 4.0.0.0. Win32-Version: 4.7.2053.0 built by: NET47REL1. CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
mscorlib.resources Assembly-Version: 4.0.0.0. Win32-Version: 4.7.2053.0 built by: NET47REL1. CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
Microsoft.GeneratedCode Assembly-Version: 1.0.0.0. Win32-Version: 4.7.2117.0 built by: NET47REL1LAST. CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
System.Drawing.resources Assembly-Version: 4.0.0.0. Win32-Version: 4.7.2053.0 built by: NET47REL1. CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing.resources/v4.0_4.0.0.0_de_b03f5f7f11d50a3a/System.Drawing.resources.dll.
************** JIT-Debuggen ************** Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der Konfigurationsdatei der Anwendung oder des Computers (machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden. Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten Ausnahmen an den JIT-Debugger gesendet, der auf dem Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
Edited by user 22 September 2019 10:01:50(UTC)
Originally Posted by: overlord Problem for me is I can't change font, bold, italic or underline options. Toolbar is there but not working. Windows 10 Pro x64 v1903 if it helps. Please describe when it doesn't work? 1) Create a text region 2) Ensure Region is focused 3) Try to change font settings. Is it working? Originally Posted by: overlord And a suggestion, the font selection should be with searchable combobox. It is currently searchable actually. Just press first char of the font name you want while dropdown is opened.
Originally Posted by: mkraska I get a (recoverable) soft crash when browsing fonts with the font selector widget. The preview of some fonts is empty in the dropdown list. (Font doesn't support style regular) Thank you. Will fix it. Originally Posted by: mkraska Also, I recommend to set arial as default font of text widgets (as in Writer plugin). Yes, will do this. Previously (before TextRegion reviewed) it was not possible. Originally Posted by: mkraska I guess we will see the option to apply attributes to selected text instead of the whole region soon. Writer Region is best one for this kind of needs.
Originally Posted by: Andrey Ivashov Please describe when it doesn't work? 1) Create a text region 2) Ensure Region is focused 3) Try to change font settings. Is it working? It is currently searchable actually. Just press first char of the font name you want while dropdown is opened.
I had figured text has to be focused, not region. Edited the previous message near 1 hour ago, sorry. I have mentioned the searchable combobox as in office word, msword, etc. Not only for the first character of the fonts.
Originally Posted by: Andrey Ivashov Originally Posted by: mkraska I guess we will see the option to apply attributes to selected text instead of the whole region soon. Writer Region is best one for this kind of needs. Yes, as for now I agree. But I bet every new user will be frustrated when finding out that text formatting can't be applied just to the selection. Another (hopefully temporary) workaround is to embed a text region into another text region and to format it separately. However, there are alignment glitches and you can't copy and past such embedded texts: |
Hello, Oh !, the version of Smath Studio 7204 has the same problem in displaying the description of variables as the version of SS 7200. , Best Regards Carlos
Hello, I don't experience this problem in 7204. |
Originally Posted by: CBG Oh !, the version of Smath Studio 7204 has the same problem in displaying the description of variables as the version of SS 7200. Looks like you have saved broken document in 7200. The issue there was that it was not able to load translations for descriptions, so after save it saved everything except those descriptions. Now there are no descriptions, because these entries lost.
Originally Posted by: mkraska Another (hopefully temporary) workaround is to embed a text region into another text region and to format it separately. However, there are alignment glitches and you can't copy and past such embedded texts: Both issues are well known and I'm working to fix them.
Originally Posted by: mkraska Yes, as for now I agree. But I bet every new user will be frustrated when finding out that text formatting can't be applied just to the selection. That image looks same SS 6179 fails to open SS 7109. Just observed similar incompatibility ... ?
IMHO, all those glorious text region(s) in subject have strictly no interest in the math suite of project(s). For publishing, SS 6179 is very similar/superior to OriginLab 7.5... superior to Mathcad 11. No shame to publish the attached ... organize at will. Images in Forum aren't 1/1 in file any more [several months]. Just suggestive for interested users.
Originally Posted by: Andrey Ivashov Originally Posted by: CBG Oh !, the version of Smath Studio 7204 has the same problem in displaying the description of variables as the version of SS 7200. Looks like you have saved broken document in 7200. The issue there was that it was not able to load translations for descriptions, so after save it saved everything except those descriptions. Now there are no descriptions, because these entries lost. . Hello, The file I used did not record it in the SS-7200 version, and it was the one I used to test the SS-7202 version, which worked perfectly. I did another test on SS-7204 with files that I didn't open in any of the mentioned versions, and the function of displaying the variable description fails. Best Regards Carlos
Hello Andrey Originally Posted by: Andrey Ivashov Originally Posted by: CBG Oh !, the version of Smath Studio 7204 has the same problem in displaying the description of variables as the version of SS 7200. Looks like you have saved broken document in 7200. The issue there was that it was not able to load translations for descriptions, so after save it saved everything except those descriptions. Now there are no descriptions, because these entries lost. Here is the same file running on a portable version of SS-7202, which shows that the description of variables appears complete. The same file running in the SS-7204 version, which shows that the description of variables does not appear complete. Best Regards Carlos
Carlos, Originally Posted by: CBG The same file running in the SS-7204 version, which shows that the description of variables does not appear complete. I cannot reproduce this issue. Please could you send a file in question to me by e-mail? Thanks in advance!
Hello Andrey: Here is a sheet of the file that shows the behavior that indicates in the post with the versions of SS-7202 and SS-7204. Test_SS7202_SS7204.sm (49kb) downloaded 24 time(s).I hope it helps to find the problem. Thank you Best Regards Carlos
Originally Posted by: CBG Here is a sheet of the file that shows the behavior that indicates in the post with the versions of SS-7202 and SS-7204. Test_SS7202_SS7204.sm (49kb) downloaded 24 time(s).I hope it helps to find the problem. Thank you! Reproduced now. Will fix soon. Regards.
I can't change the default font size. Currently it is set at 10. If I try to change it in the "ribbon", it just switches back to 10 instantly. If I try to via tools-> options, it will change for one text region, but as soon as I finish it changes back to 10.
Also any text that was 8 font as soon as I move it or copy it, it changes to size 10.
Joined: 07/12/2018(UTC) Posts: 44 Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: RFreund I can't change the default font size. Currently it is set at 10. If I try to change it in the "ribbon", it just switches back to 10 instantly. If I try to via tools-> options, it will change for one text region, but as soon as I finish it changes back to 10.
Also any text that was 8 font as soon as I move it or copy it, it changes to size 10. Hi, I confirm this fact. Unfortunately, the font size cannot be changed and is always set to '10' Best regards, Andrei
