![Jason C Jason C](/forum/images/noavatar.gif) ![](/forum/Images/Ranks/Member.png) Rank: Member Groups: Registered
Joined: 15/10/2019(UTC) Posts: 12 ![United States United States](/forum/Content/images/flags/US.png) Location: CA
Firstly thank you for such a wonderful free alternative to MathCad 15. Please see attached .sm file. The comments describe the bug ... Thanks in advance test bug.sm (17kb) downloaded 30 time(s).
![omorr omorr](/forum/resource.ashx?u=274) ![](/forum/Images/Ranks/Administration.png) Rank: Administration Groups: Registered, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,740 ![Man Man](/forum/Themes/yafvision/male.gif) ![Serbia Serbia](/forum/Content/images/flags/SP.png) Was thanked: 318 time(s) in 268 post(s)
Originally Posted by: Jason C ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) Firstly thank you for such a wonderful free alternative to MathCad 15. Please see attached .sm file. The comments describe the bug ... Thanks in advance test bug.sm (17kb) downloaded 30 time(s). Hello, Did not reproduce it... ![maybebyg.PNG](/forum/resource.ashx?a=31745&b=2) Regards, Radovan |
![thanks](/forum/Themes/yafvision/heart_small.png) 2 users thanked omorr for this useful post.
on 15/10/2019(UTC), on 15/10/2019(UTC)
![alyles alyles](/forum/images/noavatar.gif) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered
Joined: 23/03/2016(UTC) Posts: 278 ![United States United States](/forum/Content/images/flags/US.png) Was thanked: 91 time(s) in 57 post(s)
Originally Posted by: omorr ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif)
I could not reproduce either.. |
![thanks](/forum/Themes/yafvision/heart_small.png) 1 user thanked alyles for this useful post.
![ndtma ndtma](/forum/resource.ashx?u=3905) ![](/forum/Images/Ranks/Advanced-Member.png) Rank: Advanced Member Groups: Registered
Joined: 05/06/2014(UTC) Posts: 348 ![Man Man](/forum/Themes/yafvision/male.gif) ![Sri Lanka Sri Lanka](/forum/Content/images/flags/LK.png) Location: Colombo Was thanked: 127 time(s) in 82 post(s)
Originally Posted by: alyles ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) Originally Posted by: omorr ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif)
I could not reproduce either.. Yes, did not reproduce. |
Hmm, I just re-tested on my home PC, freshly booted, same problem. appVersion(3) = "0.99.7030" not .7219 <- Could this be the difference? ![Capture.PNG](/forum/resource.ashx?a=31749&b=2) Edited by user 15 October 2019 19:07:28(UTC)
Originally Posted by: Jason C ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) Hmm, I just re-tested on my home PC, freshly booted, same problem. appVersion(3) = "0.99.7030" not .7219 <- Could this be the difference? ![Capture.PNG](/forum/resource.ashx?a=31749&b=2) I can confirm this hangs on 7030. I was running 7219 before and did not have an issue. My guess is this should be fixed in next stable release and already seems to be fixed in Beta releases. The question is whether or not the "fix" is intentional or not. |
OK thanks. I will install 7219. Hopefully my Maxima plugin continues to work.
![Jean Giraud Jean Giraud](/forum/resource.ashx?url=http%3a%2f%2fen.smath.info%2fforum%2fUploads%2f9678.PNG&width=100&height=100) Rank: Guest
Joined: 04/07/2015(UTC) Posts: 6,866 ![Canada Canada](/forum/Content/images/flags/CA.png) Was thanked: 981 time(s) in 809 post(s)
Originally Posted by: Jason C ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) I will install 7219. IMHO, not the best option yet. Who can guess what the angle for loop should be doing ? There are no maths associated with ! ![Test What.PNG](/forum/resource.ashx?a=31750&b=2)
Originally Posted by: Jean Giraud ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) Originally Posted by: Jason C ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) I will install 7219. IMHO, not the best option yet. Who can guess what the angle for loop should be doing ? There are no maths associated with ! ![Test What.PNG](/forum/resource.ashx?a=31750&b=2) angle was originally used as such, but I modified it as a troubleshooting step, with no change to the bug's behavior loss := loss + I2ttot(sin(angle*deg)*Ipk)
Originally Posted by: Jason C ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) OK thanks. I will install 7219. Hopefully my Maxima plugin continues to work. It works properly on .7219. But Maxima doesn't work.
Originally Posted by: Jason C ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) But Maxima doesn't work.
What error do you get? Maxima works fine on my end. May need to update the plugin. |
^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030? EDIT: I was able to get Maxima running with .7219. Edited by user 17 October 2019 16:15:03(UTC)
Originally Posted by: Jason C ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) I just re-tested on my home PC, freshly booted, same problem. appVersion(3) = "0.99.7030" not .7219 No matter SS version, by far not a Mathcad clone. Show some Mathcad snippets ... would help doctor the patient. What from Maxima ? Plot, Solve ...
Originally Posted by: Jason C ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) ^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030?
Not sure? Maybe Martin can answer. I already had maxima setup on a previous version. I simply updated to 7219 and Maxima came along for the ride. |
Originally Posted by: alyles ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) Originally Posted by: Jason C ![Go to Quoted Post Go to Quoted Post](/forum/Themes/yafvision/icon_latest_reply.gif) ^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030?
Not sure? Maybe Martin can answer. I already had maxima setup on a previous version. I simply updated to 7219 and Maxima came along for the ride. I was able to install Maxima with .7219, thank you.
