SMath Studio Forum
Bugs & Problems
Some lines turn into black background when loading in another PC
I'm working on the same file at home and at work. Today when I loaded it at work some lines' background turned black. This is version "0.99.7219.26345" I've been playing with slightly different versions at home and work because of other bugs. Has anyone seen this?
Change the background color of each line from black to white.
Originally Posted by: Jason C Has anyone seen this ? That freak is very recent from SS 7219. Edit menu Select all, background White.
I remember it already happened a long time ago... Can you share the file that loads with different backgrounds? |
Originally Posted by: Davide Carpi I remember it already happened a long time ago... The problem is not constant from all SS 7219 download. Neither it appeared from day 1. It first appeared random, now seems every times. Can it be caused by Win updates crashing some settings ? Thanks Davide.
Originally Posted by: Jean Giraud Originally Posted by: Jason C Has anyone seen this ? That freak is very recent from SS 7219. Edit menu Select all, background White. Problem is I have a bunch of expressions highlighted in various colors (e.g. user inputs, results), and they would get lost.
Originally Posted by: Jason C Problem is I have a bunch of expressions highlighted in various colors (e.g. user inputs, results), and they would get lost. From the few crappy all black SS 7219 downloaded from the forum, NONE got lost following the procedure previously offered. Another way of doing is as simple: open the document [Work sheet], they are all black, Edit, Select all, A from menu, select yellow. You should see all of them yellow on black. Change background to white, Edit, Select all, A from menu, change yellow for black. What we don't know yet: is it Smath or Windows ? Is SS 7219 not compatible to Win 7 [per say or Win 10] ? Who cares if you lose decorative inputs/results ?
... download this recently created SS 6179. What do you get in your recent SS 7219, all black ? Maths Polygon Area_Perimeter.sm (56kb) downloaded 22 time(s).
Thanks. The only black area is attached below.
Originally Posted by: Jason C Thanks. The only black area is attached below. Yes, because I created this way [yellow maths on black background]. BTW: black is not [0,0,0] rather [1,1,1]. Now, if you take a blank work sheet and recompose on your SS 7219 key stroke by key stroke, i.e: not copy/paste any single piece, then save, then close PC, then re-open PC, Smath, work sheet. Does it show all maths black ? We must exhaust this bug before calling the Sky Hoke. Thanks for reporting ... waiting for more.
Originally Posted by: Jason C I'm working on the same file at home and at work. Today when I loaded it at work some lines' background turned black. This is version "0.99.7219.26345" I've been playing with slightly different versions at home and work because of other bugs.
Has anyone seen this? That black bug is annoying but easy to manage between SS 7219 area pasted in SS 6179. That does solve your home/work switch over. Bug Black 7219.sm (60kb) downloaded 21 time(s).
Bug is still present in Jean's file. Funny thing is this was MY work. His items came were hit or miss. I'm working off of portable version. See file post #3Edited by user 11 January 2021 18:48:34(UTC)
Originally Posted by: ElSid Bug is still present in Jean's file. Funny thing is this was MY work. His items came were hit or miss. I'm working off of portable version. See file post #3 The bug is solved since the transparent background is no more saved as black, but existing files are still affected because the background color was saved as black (#000000). Because it is a legit operation to set the background as black it might be excessive to force it as transparent by the program; IMO the fix should be done manually (if you think there are a lot of file affected and is safe to bruteforce replace the backgrounds, a batch script can do the job easily) Edited by user 11 January 2021 19:44:56(UTC)
Originally Posted by: ElSid I have the same issue (0.99.7251.32800) This bug started at SS 7610 from recollection, was reported. Select all from Edit, background white.
SMath Studio Forum
Bugs & Problems
