Here is a Maxima version, including the fit procedure. Note the use of parametric() in order to get evenly distributed points in the log plot. logplot.sm (146kb) downloaded 27 time(s). |
on 03/12/2019(UTC), on 04/12/2019(UTC)
Originally Posted by: mkraska Here is a Maxima version, including the fit procedure. Note the use of parametric() in order to get evenly distributed points in the log plot. Thanks Martin. 1. added the source experiment notes 2. added Weibull MLE example. Jean Utilities logpts [Beta_Poisson].sm (354kb) downloaded 29 time(s).
