SMath Studio Forum
Samples
Program for Linear and Polynomial Fit
Was thanked: 21 time(s) in 17 post(s)
Originally Posted by: Jean Giraud
Hope this document will tranquilize visitors/users !
Jean.
If that's what you think.
Originally Posted by: MarB If that's what you think. Does it work for you ... SS 7251 users please confirm ?
Originally Posted by: Jean Giraud Originally Posted by: MarB If that's what you think. Does it work for you ... SS 7251 users please confirm ? Hello Jean Yes, It works Carlos
Originally Posted by: Jean Giraud Originally Posted by: MarB [url=/forum/yaf_postsm60156_Program-for-Linear-and-Polynomial-Fit.aspx#post60156][/url]If that's what you think. Does it work for you ... SS 7251 users please confirm ?
It works. Thank you MarB. |
Originally Posted by: MarB That's my solution - to separate the functions from matrix building, - to use vectorize for speed Apparently, the function f(#x):=1 if n=0 has a problem?. Or is it redundant? For values n>0, the "otherwise" condition yields correct results irrespective of values in "if" condition. Please check. Edited by user 12 December 2019 13:47:51(UTC)
Hi, just put the 1 into a 1x1 matrix. That's all. (And if you want to use units with the X Vector, just remove the eval and evaluate symbolically.) Originally Posted by: MarB Originally Posted by: ndtma Originally Posted by: MarB That's my solution - to separate the functions from matrix building, - to use vectorize for speed Apparently, the function f(#x):=1 if n=0 has a problem?. Or is it redundant? For values n>0, the "otherwise" condition yields correct results irrespective of values in "if" condition. Please check.
Originally Posted by: MarB just put the 1 into a 1x1 matrix. That's all.
Hi Still the same error when n=0. Better if you can post the SM file please. Edited by user 12 December 2019 16:25:22(UTC)
Sorry, I didn't realize, that vectorize behaves unexpectedly (to me), when the function does not include 'x'. So I changed f to f(x):=[1+0*x] and now it works. The file is attached. PolyFit.sm (12kb) downloaded 18 time(s).I would expect the results of g and h to be the same, and to be a 3 items long vector.
1 user thanked MarB for this useful post.
Hi Now I get same results as yours. But the result (19.0833) of the Polyfit() function when n=0 ----> Does it have any meaning? I have no idea. I was only testing it for all possible conditions.. Cheers MarB. Note: Incidentally, 19.0833 happens to be the Mean of Y vector. Edited by user 12 December 2019 17:55:26(UTC)
| Reason: Additional checks |
IMHO ... no need to complicate matters. Modular design is easier to fix. More automated is OK if you intend to poly for the entire Planet. PolyFit (2).sm (47kb) downloaded 18 time(s).
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 830 time(s) in 526 post(s)
Originally Posted by: ndtma ... But the result (19.0833) of the Polyfit() function when n=0 ----> Does it have any meaning? I have no idea. I was only testing it for all possible conditions.. ...
Hi. This is in case you want to interpolate with an horizontal line. PolyFit.sm (160kb) downloaded 27 time(s). PolyFit.pdf (749kb) downloaded 20 time(s).Best regards. Alvaro.
SMath Studio Forum
Samples
