SMath Studio Forum
Questions
Local Assignment Operator MathCAD Work-Around
I have a MathCAD sheet that I am trying to convert to be able to use in SMath. I have attached a few lines from the MathCAD sheet that I am having problems with. How can you achieve the same thing in SMath, since there isn't a local definition operator that I can find in SMath? Thanks!!
The local definition is <- is simply := You should be able to spline your matrix from there. SplineRectangularMatrix.sm (87kb) downloaded 27 time(s).
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 830 time(s) in 526 post(s)
Hi. SMath doesn't have the Mathcad column extractor as operator, but as function: you can use col(sigma.data,7-j). Also, notice that i=sqrt(-1) is SMath, this is, not 1i, like in mathcad.
Best regards. Alvaro.
SMath Studio Forum
Questions
