Hello to all. I have traced these three functions, that depend on time, on the graph. How can I insert numbered points, superimposed on the traced functions, so that the same numbering corresponds to the same instant of time? To be clear, I should do something like the following figure … This is the .sm file: CALCOLI TESI manovra.sm (70kb) downloaded 15 time(s).thanks in advance for the help
using some good tips posted by Jean, you could do this: CALCOLITESImanovra_s.sm (79kb) downloaded 31 time(s).I preferred to refer to actual times and not to anonymous labels; however you can use the same methodology more easily sergio
1 user thanked PompelmoTell for this useful post.
Originally Posted by: Ale16595 I have traced these three functions Can you trace these functions from the previously doctored document. Why jump ship [new thread] from suite to suite ?
Originally Posted by: Ale16595 To be clear, I should do something like the following figure ⦠Easy ... take the DE that I doctored before there may be some sanity wrt the other two graphs.
