#1 Posted : 28 January 2020 00:30:51(UTC)
Global fitting session [0 .. 14]
1. al_nleqsolve point select equalities
valid for noisy data via user piecewise linear.
2. Levenberg-Marquardt: generally valid [fails Frechet]
3. Cholesky matrix solver ... solves all, faster
model function(s) parameters, linfit components,
remarkable linfitCheby, polyorder, direct discrete data.
............................ rational fraction.
EMERITUS => Conjugate gradient Minimize(init,iter)
Genfit_0 Read First.sm (33kb) downloaded 46 time(s).
Genfit_2 L-M AUTOMATED PieceWise-Global Reflexive Copy.sm (70kb) downloaded 34 time(s).
Genfit_4 linfit HyperRobust [Ge Crystal] Copy.sm (83kb) downloaded 28 time(s).
Genfit_7 GenfitMatrix Copy Master ToolBox Copy.sm (63kb) downloaded 26 time(s).
Genfit_9 Chemist.sm (35kb) downloaded 28 time(s).
Genfit_5 LinfitCheby Order [HadCRU] Copy.sm (121kb) downloaded 27 time(s).
Genfit_8 Poly 000 Order System.sm (21kb) downloaded 30 time(s).
Genfit_3 L-M AUTOMATED PieceWise Carlos Original Copy.sm (131kb) downloaded 29 time(s).
Genfit_6 Rational Auto-init ITER [LongRange type_J] Copy.sm (124kb) downloaded 26 time(s).
Genfit_11 Pharmacokinetics LMSA ... [Carlos 2020].sm (51kb) downloaded 23 time(s).
Genfit_10 Frechet.sm (97kb) downloaded 27 time(s).
Genfit_13 NON-Linear.sm (38kb) downloaded 39 time(s).
Genfit_1 L-M AUTOMATED Carlos 20200115 [Exampless] Copy.sm (266kb) downloaded 26 time(s).
Genfit_14 AUTOMATED al_nleqsolve.sm (84kb) downloaded 27 time(s).
Genfit_12 Pharmacokinetics LM ... [Carlos 2018].sm (56kb) downloaded 23 time(s).
on 28/01/2020(UTC)
#2 Posted : 28 January 2020 17:34:28(UTC)
1 ... please: recycle Genfit_14
replace by high pro refreshed/augmented.
2. Add Genfit_15 [Thiele Procedure]
Genfit_15 Thiele Procedure [Carlos-Jean].sm (77kb) downloaded 21 time(s).
Genfit_14 AUTOMATED al_nleqsolve.sm (86kb) downloaded 24 time(s).
#3 Posted : 30 January 2020 19:27:00(UTC)
... add this Meritas to your tool box.
Genfit_16 MERITAS al_nleqsolve.sm (30kb) downloaded 14 time(s).
Offline CBG
#4 Posted : 30 January 2020 19:44:43(UTC)
CBG
Hola Jean
This is my best setting for "Genfit_10 Frenchet" in SS-6179
with LM using 6 data, since an out of memory error occurs using all data.
SS-7251 solves it without any problem with all the data.
Genfit_10 Frenchet LMSA ..SS6179.sm (57kb) downloaded 15 time(s).
Genfit_10 Frenchet LMSA ..SS7251.sm (46kb) downloaded 24 time(s).
Offline CBG
#5 Posted : 30 January 2020 20:45:05(UTC)
CBG
Hola Jean
Genfit_16 MERITAS resolved with LMSA in SS-6179 and SS-7251.
Genfit_16 MERITAS LMSA_SS6179.sm (54kb) downloaded 19 time(s).
Genfit_16 MERITAS LMSA_SS7251.sm (53kb) downloaded 33 time(s).
#6 Posted : 31 January 2020 13:54:58(UTC)
Originally Posted by: CBG Go to Quoted Post
Hola Jean
This is my best setting for "Genfit_10 Frechet" in SS-6179
Thanks Carlos, got 9 points superb fit !
Next will check MERITAS ...
Genfit_10 Frenchet LMSA ..SS6179.sm (56kb) downloaded 19 time(s).
#7 Posted : 31 January 2020 17:35:11(UTC)
Hola Jean
Thanks Grand Doctor Carlos ...
So, my native SS 6179 suffers numerical issue
that SS 7251 cures in your SS 6179 ... Ah !
LMSA in native SS 6179 takes much higher TOL [typical 0.0001/0.00001]
F.B. Hildebrand wrote "fitting is an art ..."
Can't be more right !
