Joined: 16/04/2020(UTC) Posts: 65 Location: France Was thanked: 25 time(s) in 16 post(s)
Hello, I am having this issue evaluating the vectorized multiplication: I don't know what the problem could be. I started today switching definitely from Mathcad Prime 5 and started rewriting some codes. Really happy with the decision I made, and also with the latest SMath studio version, I am running 0.99.7251 SMath. Thank you in advance for your help, Alvaro Gavilán Vectorize.sm (7kb) downloaded 17 time(s).
Matrices are multiplied like in a matcade Edited by user 16 April 2020 08:43:37(UTC)
Just a matter of isolating the code col(A,1), col(A,2) are not like function.
This way it works. Edited by user 16 April 2020 21:55:06(UTC)
There are some more issues with the vectorize function |
Thank you all for your quick responses! Problem solved with ndtma solution. Thank you Edited by user 17 April 2020 04:10:44(UTC)
| Reason: Image size
Originally Posted by: ndtma There are some more issues with the vectorize function Nice code SS 7251, not supported SS 6179.
Make your Steel Bar project Engineer style, all at once.
Thank you Jean for your suggestion. I would rather use a function, because in various parts of my worksheet (beam design), I need that function. It would be like this: AG24042020-Steel area.sm (7kb) downloaded 14 time(s).
Originally Posted by: Alvaro Gavilá I would rather use a function, because in various parts of my worksheet (beam design), I need that function. Maybe like this. Project SteelBar.sm (24kb) downloaded 31 time(s).
Originally Posted by: ndtma here are some more issues with the vectorize function
Vectorize function without loops. Vectorize_Eady.sm (16kb) downloaded 14 time(s). |
