Offline hawe
#1 Posted : 18 April 2020 15:27:08(UTC)
hawe
Was thanked: 3 time(s) in 2 post(s)
Copy from one page to an other shows different behavior of sys P
I know that eval will doctor (hello Jean :-) to the same result.
but why is eval necessary in the second case und how can I see if eval is necessary?
#2 Posted : 18 April 2020 16:30:50(UTC)
Something in there does not cut the mustard.
Attach the creator document to be copied on blank sheet
Offline hawe
#3 Posted : 18 April 2020 17:07:02(UTC)
hawe
the 2 versions of sys
sys1.sm (24kb) downloaded 12 time(s).
sys2.sm (30kb) downloaded 10 time(s).
#4 Posted : 18 April 2020 18:28:12(UTC)
Not same α° between the two documents !
Again: too specific rectangular construction of polygon.
They are constructed from vertices coordinates.
That was exemplified few days ago [Area, Perimeter, Centroid]
Arc length on Engineering curve is partial perimeter,
it goes in triplet [A,P,C].
#5 Posted : 18 April 2020 19:11:20(UTC)
The other conceptual pitfall is your rotation.
rot(,) *[2*2] is commutative for only [2*2] systems [square/rectangle...]
The universal code for XY longer than [2*2] ... XY*rot(,)
If you don't follow this rule, Mathcad red, Smath error ...
#6 Posted : 18 April 2020 22:54:47(UTC)
From there, you can compute [Area, Perimeter, Centroid]
as per the "Maths Polygon" previously posted.
As well for the native [full/reduced by list]
as for the rotated of any angle.
read NOT commutative
Rotate Gerono.sm (15kb) downloaded 8 time(s).
#7 Posted : 18 April 2020 23:41:53(UTC)
... complete the tour [A,P,C]
Rotate Gerono.sm (26kb) downloaded 10 time(s).
Offline overlord
#8 Posted : 19 April 2020 05:32:56(UTC)
Turkey
Was thanked: 509 time(s) in 339 post(s)
Difference between two calculation occurs because of numeric and symbolic optimization.
Just right click and select Optimization>Numeric for the copied formula in sys2.sm file
This false flag happens a lot. Nothing is wrong here. As usual, the culprit is optimization.
Offline hawe
#9 Posted : 19 April 2020 14:15:53(UTC)
hawe
Many thanks to hit the nuke of my question
and many thanks to Jean for pointing out problems which I do not see in my limited perspective.
