23 Pages«<1920212223>
Offline uni
#401 Posted : 11 August 2019 14:05:37(UTC)
uni
Updated.
As we see the case was in the path to the license file. I have Maple 6 installed therefore the path is exists in the registry. In general, you need to set the environment variable MAPLE_LICENSE_ROOT. I do it implicit now when call interpreter. At last it must works now.
Russia ☭ forever
Viacheslav N. Mezentsev
on 11/08/2019(UTC),  on 11/08/2019(UTC),  on 11/08/2019(UTC)
Offline ndtma
#402 Posted : 11 August 2019 16:33:14(UTC)
ndtma
Sri Lanka
Thank you Uni. All plots works fine now.
Offline uni
#403 Posted : 11 August 2019 16:39:13(UTC)
uni
Ok now. We are ready for try to use all plots from the Maple Plotting Guide.
Maple Plotting Guide.pdf (596kb) downloaded 137 time(s).
Russia ☭ forever
on 11/08/2019(UTC),  on 12/08/2019(UTC),  on 12/08/2019(UTC)
Offline uni
#404 Posted : 22 April 2020 12:55:21(UTC)
uni
Updated.
MaplePlot changed for support setprop() function.
Russia ☭ forever
on 22/04/2020(UTC),  on 22/04/2020(UTC)
Offline AleksMoisei
#405 Posted : 15 May 2020 14:43:36(UTC)
AleksMoisei
Подскажите пожалуйста как использовать данный плагин, чтобы построить график по точкам из матрицы.
Quote:
mat(7.5,5,1.4096,27,5,1.7731,80,5,1.8508,80,10,1.7223,27,10,1.5925,7.5,10,1.0883,7.5,5,1.4096,7.5,10,1.0883,27,10,1.5925,80,10,1.7223,80,15,1.6104,27,15,1.4452,7.5,15,0.8863,7.5,10,1.0883,7.5,15,0.8863,27,15,1.4452,80,15,1.6104,80,20,1.5123,27,20,1.3229,7.5,20,0.7476,7.5,15,0.8863,7.5,20,0.7476,27,20,1.3229,80,20,1.5123,80,25,1.4254,27,25,1.2197,7.5,25,0.6464,7.5,20,0.7476,7.5,25,0.6464,27,25,1.2197,80,25,1.4254,80,30,1.3479,27,30,1.1314,7.5,30,0.5693,7.5,25,0.6464,7.5,30,0.5693,27,30,1.1314,80,30,1.3479,80,35,1.2784,27,35,1.055,7.5,35,0.5087,7.5,30,0.5693,7.5,35,0.5087,27,35,1.055,80,35,1.2784,80,40,1.2158,27,40,0.9883,7.5,40,0.4597,7.5,35,0.5087,7.5,40,0.4597,27,40,0.9883,80,40,1.2158,80,45,1.159,27,45,0.9295,7.5,45,0.4193,7.5,40,0.4597,7.5,45,0.4193,27,45,0.9295,80,45,1.159,80,50,1.1072,27,50,0.8774,7.5,50,0.3855,7.5,45,0.4193,63,3)
Offline uni
#406 Posted : 15 May 2020 16:57:18(UTC)
uni
Так, например.
mapletools.pointplot3d.sm (25kb) downloaded 60 time(s).
mapletools.pointplot3d.pdf (765kb) downloaded 37 time(s).
Russia ☭ forever
on 15/05/2020(UTC),  on 15/05/2020(UTC),  on 16/05/2020(UTC)
Offline AleksMoisei
#407 Posted : 16 May 2020 23:58:27(UTC)
AleksMoisei
Спасибо большое, буду разбираться теперь. Без вас бы и не понял как, а так есть шанс
Offline uni
#408 Posted : 17 May 2020 00:19:42(UTC)
uni
На самом деле это "костыль", т.к. нужно равно владеть языком maple и умением работы в SMath Studio. Это сложно. Пока приходится пользоваться таким подходом, т.к. времени разобраться и доработать 3D Plot нет.
Там ещё не все вставки почему-то у меня срабатывали при компоновке окончательного выражения. Пока не смотрел в чём дело. По идее хорошо бы ещё сетку наложить сзади. Этот график "крутить" можно, задавая значения указанных углов.
Russia ☭ forever
Offline AleksMoisei
#409 Posted : 17 May 2020 09:37:46(UTC)
AleksMoisei
Вчера или сегодня просидел до 4-х утра пробовал все настройки plot3d из Maple) и заметил что когда точки имеют одинаковые координаты их не прорисовывает
Offline uni
#410 Posted : 17 May 2020 15:09:08(UTC)
uni
Updated.
Changes:
- DeviceType property added for MaplePlot, now you can choose image quality between gif and jpeg format;
- refactored.
Russia ☭ forever
Offline uni
#411 Posted : 17 May 2020 17:05:54(UTC)
uni
Now more stable (gif image used).
mapletools.pointplot3d.sm (26kb) downloaded 63 time(s).
Russia ☭ forever
on 17/05/2020(UTC),  on 17/05/2020(UTC)
Offline uni
#412 Posted : 27 May 2020 20:11:50(UTC)
uni
Maple version.
Russia ☭ forever
Offline overlord
#413 Posted : 08 October 2020 16:32:35(UTC)
Turkey
The error below is generated on v0.99.7579 (mono & wine) with my VoidLinux setup.
I don't know if maple works only with Windows. Couldn't find anything mention this.
Offline Razonar
#414 Posted : 10 October 2020 02:12:14(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Hi. In my system, Windows 10, it is "out.tmp", not "out.tm"
Offline overlord
#415 Posted : 10 October 2020 02:54:01(UTC)
Turkey
It is also "out.tmp" in my linux setup.
Message is just too long for tooltip area I guess.
You can see the "leg of p" barely, but it is there.
Actualy maple can read from "out.tmp" file in linux.
But obviously it can not create and read from it in linux on the fly during calculation.
Not creating temp file occurs even you are root or run smath with sudo by the way.
How I know this, first I had created an empty "out.tmp" file.
Maple gived the result as int(sin(x),x)="empty".
Then I had copied the "out.tmp" file from windows machine.
Maple gived the result as int(sin(x),x)=(x*sqr(19)+5)/sqr(19).
Which is wrong and result of another calculation from windows.
Offline Razonar
#416 Posted : 10 October 2020 03:51:57(UTC)
Razonar
Uruguay
Interesting. You have then a workaround. Just edit any time out.tmp, but please, put the correct answer next time!
Already, outside of joke, the plugin can write the file "in.tmp" correctly? This is, with the instruction for doing the integral.
And have the files in and out .tmp correct attributes for read/write operations?
I don't know, but maybe your issue is related with this:
"UNIX and Linux Installation
No special single user version of Maple exists for UNIX or Linux. The number of users is controlled by the license file."
from: https://math.feld.cvut.c...ecek/maple/install6.html
This mean that under Linux you need a daemon for the license manager in a network setup.
Edited by user 10 October 2020 04:00:45(UTC)  | Reason: Not specified
Offline uni
#417 Posted : 15 October 2020 01:53:27(UTC)
uni
I have not tested the current version on Linux, in theory it might work. I'm on vacation now and I can't check it out. The main problems can be related to paths and access rights. Some errors can be viewed in the log file if you enable debugging.
Russia ☭ forever
Offline overlord
#418 Posted : 01 March 2021 22:57:30(UTC)
Turkey
Here is a dirty trick to make maple work under linux.
You will need wine installed on your system cause it uses wineconsole.
While SMath can still be run with mono, just this command will need wine.
Don't forget to change optimization to symbolic if you are making a symbolic calculation.
PS: I have revised the code, now window shouldn't appear during calculation.
cmaple.zip (1kb) downloaded 22 time(s). (no window popup revise)
1 - extract zipfile and move cmaple.sh to plugins bin directory.
it should be usually under /home/<username>/.config/SMath/extensions/plugins/<mapleplugindirectory>/<maplepluginversion>/bin
2 - make sure cmaple.sh bash file is executable under terminal.
> chmod 755 cmaple.sh
3 - rename cmaple.exe to maple.exe.
> mv cmaple.exe maple.exe
4 - make a symbolic cmaple.exe link to cmaple.sh under terminal.
> ln -s cmaple.sh cmaple.exe
it should look like this.
Edited by user 03 March 2021 01:59:38(UTC)  | Reason: Not specified
Offline uni
#419 Posted : 05 March 2021 08:15:37(UTC)
uni
Updated.
Changes:
- added support for nthroot().
Russia ☭ forever
on 05/03/2021(UTC),  on 05/03/2021(UTC)
Offline overlord
#420 Posted : 05 March 2021 20:59:10(UTC)
Turkey
Updated.
Changes:
Hi uni,
Thanks you for your quick response to my pm and updating the plugin.
It works now but with a small issue.
Tried with both optimizations but cannot jump over this issue.
Result can not be parsed through plugin if nthroot is nested.
When it is written as power it can be calculated however.
Regards.
Guest (2)
