I've tried CTRL+A and changing the optimization from symbolic to numeric on this sheet already, it did not help with my calculation run time. I'm hoping somebody can lead me in the right direction! I've highlighted the loop that I'm trying to calculate. I also tried running the sheet without any units and it took under a second to calculate. Is it normal for SMath to perform this way? In-Class 2.6_1D conduction_SS and TS.sm (66kb) downloaded 12 time(s).
Joined: 28/08/2014(UTC) Posts: 1,367 Was thanked: 826 time(s) in 523 post(s)
Hi. Check Delta_t.TS please. Best regards. Alvaro.
The attached project was completed in collaboration.with the Originator. Very closely related to yours. Superb model fit c/w its inverse/solve. Inst_Thermal Insulation Copy.sm (128kb) downloaded 6 time(s).
