SMath Studio Forum
Questions
Insert columns / rows to an existent matrix
Hi all,
Is it possible to add rows / columns to an existing matrix? I couldn't find that and just created another matrix with the mxn needed.
Thanks, Paul
Select the entire matrix with the cursor and drag the rectangle that appears. |
Originally Posted by: Paul33 Is it possible to add rows / columns to an existing matrix? You can add row(s), col(s) that you have defined/valued or will define/value from elsewhere in the project ... all that to an existing matrix. Jean Utilities Matrix Treasury_1.sm (413kb) downloaded 19 time(s).
Thanks to both of you for the valuable answers
Originally Posted by: Paul33 Thanks to both of you for the valuable answers Applied to Fourier Convolution, from isolated data set. Cheers ... Jean [1983, I was up there Syncrude Fort McMurray] Paul 33.sm (58kb) downloaded 11 time(s).
SMath Studio Forum
Questions
