SMath Studio Forum
Questions
Integration not solving - No real roots
Hi All, I am doing an integration of a range. Unfortunately I cann find the solution. Can't see where is the problem. Any advice is appreciated. Page4.sm (17kb) downloaded 6 time(s).
Originally Posted by: davidlimtw I am doing an integration of a range. Unfortunately I cann find the solution. Can't see where is the problem.
Answered in your other question.
Joined: 28/08/2014(UTC) Posts: 1,369 Was thanked: 829 time(s) in 525 post(s)
Hi. You can't integrate functions defined in a "complicate" way, this is: can't integrate functions with "if", other constructors and ... solve nor roots. The workaround it's implement your own numerical integration procedure, or use a odesolver for get the numeric integral. Best regards. Alvaro.
Hi Razonar & Jean, Thanks for the advice. I still cant find a way to rewrite the equations given there is k in both side of the equation to solve. Need to solve the k in the function of w to continue calculation. Any suggestions is welcome. Thanks David
Originally Posted by: davidlimtw Thanks for the advice. I still cant find a way to rewrite the equations given there is k in both side of the equation to solve. Attach the latest document, compact conveniently.
Hi Jean,
I dont see any document.
Originally Posted by: davidlimtw Hi Jean, I don't see any document. I don't understand much in your stuff ! As it looks we can integrate something in there. Cheers ... Jean Page4 (1).sm (28kb) downloaded 5 time(s).
SMath Studio Forum
Questions
