SMath Studio Forum
Questions
How to get integration value in range
Was thanked: 2 time(s) in 2 post(s)
SmathMathCAD PrimeEdited by user 30 January 2021 17:23:22(UTC)
in Smath you have to use explicit vectorization sergio
Thanks. BTW: Whern I click "THANK" button. it shows "Error" Edited by user 30 January 2021 17:48:51(UTC)
Originally Posted by: netsonicyxf BTWï¼ When I click "THANK" button. it shows "Error" Does not work from dark age.
... hyperfast.
Integration values extended to matrix and nested arrays. Edited by user 31 January 2021 09:28:19(UTC)
@ netsonicyxf In the mean time you cogitate more integration visit SamplesSimpson ranges from exact [I only know two functions] to absolute crap. In cases considered adequate, it may still be a poor integrator. ... poor integrator on the long range of the integration variate X. This case is rescued via Romberg-Simpson ... in the attachment. Other integrations are only possible via Carlos Adaptive ∫Adaptive(f,a,b,N,ε). These two documents are minimalist visit. Good idea to first construct the project unit-less. Chhers ... Jean Integrate Compendium_20 Simpson-Romberg Adaptive.sm (140kb) downloaded 16 time(s). Integral 00000000 MASTER ToolBox.sm (478kb) downloaded 22 time(s).
Thank you friends, you always give very detailed help.
SMath Studio Forum
Questions
