7 Pages«<4567>
#101 Posted : 09 November 2017 02:04:30(UTC)
Thank you Alex, it's the same issue reported here, I'll try to fix it tomorrow Good
#102 Posted : 09 November 2017 14:45:09(UTC)
Fix committed for the latest SS BETA; I'm aware there are still some drawing issues with cases due to something in SMath Studio itself.
#103 Posted : 29 October 2019 13:50:37(UTC)
There is a problem with at() in build 7219:
It seems that the function at() isn't executed.
Materials E7-6.sm (11kb) downloaded 29 time(s).
#104 Posted : 29 October 2019 19:27:07(UTC)
Thank you Martin, I will look at it as soon as I can.
edit: fixed in later versions SS
Edited by user 16 May 2020 15:33:00(UTC)  | Reason: Not specified
#105 Posted : 03 November 2019 15:18:28(UTC)
In the attached sheet, the conversion of solution results into definitions is demonstrated in two ways:
1. Usage of Assign(), a function made for this purpose in the Maxima plugin.
2. Usage of the substitution function at() from custom functions plugin, which by syntax should be good for the purpose.
It turns out that it makes a difference whether the Solve function is inside a line block or not. In the latter case, at() comes up with a strange error message.
Solve-3.sm (21kb) downloaded 31 time(s).
#106 Posted : 16 May 2020 15:24:11(UTC)
PLUGIN UPDATED SMath Studio 0.99.7251 Nightly Build and later Beta
- Unknowns() improved to don't match integration variable of int(4);
Unknowns.sm (19kb) downloaded 25 time(s).
Edited by user 16 May 2020 15:26:02(UTC)  | Reason: Not specified
#107 Posted : 06 March 2021 18:29:00(UTC)
PLUGIN UPDATED SMath Studio 0.99.7691 Nightly Build and later
- [SS-4651] at() assignment improved to avoid unexpected substitutions when variables are given as replacements;
EDIT
either this should works correctly now:
Edited by user 12 March 2021 12:52:09(UTC)  | Reason: Not specified
on 06/03/2021(UTC),  on 06/03/2021(UTC)
Offline Jason McCool
#108 Posted : 24 March 2021 16:00:36(UTC)
Jason McCool
United States
Was thanked: 9 time(s) in 7 post(s)
Davide, thanks for developing this plugin; I use several function in here regularly. One that I just tried using that could be very useful for me is the Ceil function. In engineering we often want to always round up, so this would fit that bill well. However, it seems to only round up with respect to the base unit instead of the unit actually used. So instead of rounding a result up to the next inch (or millimeter), it rounds to the next foot (or meter). Would it be possible to account for the unit in that evaluation somehow?
Thanks,
Jason
Jason McCool
Robbins Engineering
Little Rock, AR, USA
#109 Posted : 24 March 2021 17:49:52(UTC)
Thanks,
Jason
Such a function would definitely need the target unit as input. In order to use this for display automatically, the plugin would need to suppress back-simplification to SI, which might require "Optimization None" on user side. A comprehensible operator form might put a placeholder for the unit at the index position to the lower left
ceil2.sm (4kb) downloaded 14 time(s).
#110 Posted : 24 March 2021 18:12:26(UTC)
Jason McCool
United States
Yes, that looks like it will do what I need. Good idea, Martin. Thanks!
And I like the idea of being able to define the output unit in the index position. That seems clear and streamlined as well.
Jason McCool
Robbins Engineering
#111 Posted : 25 March 2021 15:56:13(UTC)
useful, consistant, I like it... agreed. I'll add it in the next plugin update.
Edited by user 27 March 2021 18:51:55(UTC)  | Reason: typo
on 25/03/2021(UTC)
#112 Posted : 27 March 2021 18:42:00(UTC)
PLUGIN UPDATED SMath Studio 0.99.7739 Nightly Build and later
  • added Ceil(2);
  • added Floor(2);
thanks 4 users thanked Davide Carpi for this useful post.
on 27/03/2021(UTC),  on 27/03/2021(UTC),  on 28/03/2021(UTC),  on 29/03/2021(UTC)
Offline ElSid
#113 Posted : 09 April 2021 16:42:14(UTC)
ElSid
United States
Davide,
Since you are using a specialized output with the brackets and unit subscript, I would like to suggest ceil2 using a superscript for the unit. floor2 keeps the current subscript. Visually, this will help us "SEE" what was used in context to the equation/function
#114 Posted : 14 April 2021 16:07:31(UTC)
Originally Posted by: ElSid Go to Quoted Post
Davide,
I get the point but seems to me that might be confusing when exponentiations are involved Umnik
Also, the "base" could be a variable, or a simple number
Edited by user 15 April 2021 13:04:35(UTC)  | Reason: Not specified
Offline MarB
#115 Posted : 19 May 2021 10:54:46(UTC)
MarB
Was thanked: 21 time(s) in 17 post(s)
Hi!
The var2str from custom functions plugin has problems with the new release:
Code:
appVersion(4)="0.99.7808.230"
var2str(1.7,2)="1,70"
var2str(1.7,"0.00")="0002E02"
var2str(1.7,"0,00")="0002C02"
#116 Posted : 19 May 2021 12:28:41(UTC)
Yes, this is related to changes in text encoding, I'll fix it ASAP.
#117 Posted : 22 May 2021 18:38:20(UTC)
PLUGIN UPDATED SMath Studio 0.99.7808 and later
  • fixed encoding/decoding issues;
  • refactoring;
on 22/05/2021(UTC),  on 22/05/2021(UTC)
Offline PompelmoTell
#118 Posted : 24 May 2021 17:40:10(UTC)
PompelmoTell
Davide, I encountered this issue after the last update
thanks 1 user thanked PompelmoTell for this useful post.
on 24/05/2021(UTC)
#119 Posted : 24 May 2021 18:28:36(UTC)
Confirmed. I'll fix it ASAP. Crazy
#120 Posted : 24 May 2021 18:30:02(UTC)
What about if you specify Bolean completely ?
Guest (2)
Similar Topics
[Custom Functions plugin] cases SS6179 (Bugs & Problems)
by PompelmoTell 07/02/2017 19:14:23(UTC)
7 Pages«<4567>
