Offline 009jim
#1 Posted : 26 May 2021 07:18:59(UTC)
009jim
hi Folks, I am programming some equations and there is a requirement for a summation of terms, each term being a square root of a function of several variables. The method requires ignoring any negative results, i.e. where the square root of a negative number will lead to a complex number.
The terms are all have identical variables and it would be ideal if I can perform some operation on the general case term, so that the imaginary results just vanish.
Offline Razonar
#2 Posted : 26 May 2021 08:31:38(UTC)
Razonar
Uruguay
Was thanked: 834 time(s) in 528 post(s)
Hi. You can try to redefine i:=0 and see if get the desired behavior.
Offline gntech
#3 Posted : 26 May 2021 08:57:00(UTC)
gntech
Rank: Member
Sweden
There is a function called Re that returns the real part of a complex number. See example below
For reference: The counterpart is the function Im, see below.
Edited by user 26 May 2021 08:58:45(UTC)  | Reason: Not specified
#4 Posted : 26 May 2021 16:11:26(UTC)
Your description is too general w/o the formula.
Circle Complexn-circles.sm (11kb) downloaded 11 time(s).
Offline 009jim
#5 Posted : 27 May 2021 01:01:12(UTC)
009jim
hi folks, thanks for your contributions
the way I've solved my dilemma was to multiply each term by (X>0) so that whenever X is less than zero the sqrt(X*(X>0)) becomes zero.
#6 Posted : 27 May 2021 02:09:39(UTC)
You have solved nothing yet from nothing to pass QA !
Offline 009jim
#7 Posted : 27 May 2021 04:02:06(UTC)
009jim
Offline Razonar
#8 Posted : 27 May 2021 06:25:47(UTC)
Razonar
Uruguay
Hi Jim. Actually your dilemma isn't trivial and the solution that you found it's complete in the sense that you extend over the integers an operation only well defined for the natural numbers. For integers, rationals, reals, complexes, vectors, matrices, tensors ... are only conventions based on definitions by convenience, very very good ones ... but not theorems.
For example Maple have the function surd for deal with roots with integers when the usual convention doesn't work. Because power don't commute have two inverses, one by the left and other by the right, roots and logarithms, complicating the things. This is the help for the surd function from Maple website:
https://www.maplesoft.co...aple/view.aspx?path=surd
As you can see, if you ask to Maple for convert surd, it returns just x^(1/n).
So, you can define your own function pow3(x) = x^3 * (x > 0). Or maybe more general some CheckPos(x) for make more readable your expression.
#9 Posted : 27 May 2021 13:47:21(UTC)
Attach the *.sm document.
#10 Posted : 27 May 2021 15:25:19(UTC)
... do some effort:
split that monster, zap subscript, make minimalist like visiting doctor.
Page10 Split Monster.sm (477kb) downloaded 8 time(s).
