7 Pages«<567
#121 Posted : 24 May 2021 22:18:17(UTC)
Fixed, plugin updated.
on 24/05/2021(UTC),  on 25/05/2021(UTC)
Offline MarB
#122 Posted : 31 May 2021 10:17:38(UTC)
MarB
Was thanked: 21 time(s) in 17 post(s)
The function mat2sys.1 affects also the inner matrix, if evaluated numerically AND if this inner matrix contains only element.
Is that really the intended behaviour?
I wanted to build my own mat2sys.1 using num2str, ... replace mat with sys... str2num
Looks like str2num is the "culprit", at least in my own function (only while evaluating numerically).
Maybe the better question is: Is this behaviour of str2num intended?
Edited by user 31 May 2021 11:11:55(UTC)  | Reason: correction
#123 Posted : 31 May 2021 17:02:37(UTC)
There are miscellaneous applications, mostly Fourier stuff.
Fourier Geometric Coplanar COMPLEX.sm (18kb) downloaded 13 time(s).
#124 Posted : 31 May 2021 17:20:27(UTC)
... I don't understand the remaining of the demand.
#125 Posted : 31 May 2021 17:24:14(UTC)
#126 Posted : 31 May 2021 18:13:07(UTC)
The behaviour is driven by the evaluation of the outer sys(); on numerical evaluation, the "first level" of 1x1 matrices is suppressed.
I'm not sure if it is really intended, but it might be part of the special behaviours of sys() (have to check the code/ask Andrey).
Edited by user 31 May 2021 18:14:50(UTC)  | Reason: Not specified
on 31/05/2021(UTC),  on 31/05/2021(UTC)
Offline MarB
#127 Posted : 31 May 2021 19:02:53(UTC)
MarB
By now I think it's the general behaviour (intended or not), that 1×1 matrices are evaluated to its element (numeric).
That's why I use Gettype() to check if an element was found.
Offline MarB
#128 Posted : 09 June 2021 15:49:05(UTC)
MarB
Found a bug in cases in combination with for loops and continue:
Two identical loops.
If if(,,) is used, continue causes the rest to be skipped (as expected).
If cases(,,) is used, continue has no effect
appVersion(4)="0.99.7822.147"
Edited by user 09 June 2021 16:08:25(UTC)  | Reason: screenshot replaced
Offline MarB
#129 Posted : 15 June 2021 08:40:15(UTC)
MarB
Sorry for pulling this to the surface.
I am wondering if I am the only one, who's using continue/break in a similar way.
At the moment I replace every cases with if(s), when used in combination with for loops and continue/break.
Offline overlord
#130 Posted : 15 June 2021 09:19:03(UTC)
Turkey
Confirmed, with a strange behavior.
Reversing the cases makes it correct.
#131 Posted : 15 June 2021 09:46:04(UTC)
At first glance I'm not sure about the cause, I'll check it.
However looking at the screenshot I have to point out once again that in general you shouldn't put definitions inside cases().
Unlike if(), when a condition or a case fails instead of throwing an error the whole function is returned like if doesn't exists. The consequence is that every argument is exposed and preprocessed, with potential unwanted behaviors respect to the expected logic. This is on the edge of SMath possibilities, but is what makes possible to use cases() whereas if() usually fails.
#132 Posted : 15 June 2021 09:55:31(UTC)
Nothing to be afraid, is in the best interests of anyone having things to work flawlessly Good
Interesting, nice catch .
#133 Posted : 15 June 2021 13:56:43(UTC)
#134 Posted : 19 June 2021 14:12:37(UTC)
PLUGIN UPDATED SMath Studio 0.99.7822 and later Beta
  • image2rgb/image2rgba: implemented different algorithm for linux users;
  • image2rgb/image2rgba fixed exception on failed disposal of temporary files;
Offline overlord
#135 Posted : 19 July 2021 21:38:47(UTC)
Turkey
cases() refuse to be vectorized if it is a function.
Offline MarB
#136 Posted : 19 July 2021 22:13:54(UTC)
MarB
Sometimes a line at the right place helps a lot.
And hovering the mouse over an expression helps finding the glitch.
Offline overlord
#137 Posted : 20 July 2021 00:02:45(UTC)
Turkey
Hah, I get it. Mysterious (but necessary according to this) line again.
Even though I use smath several years, I still forgot some of its tricks.
No need to hover the mouse, lasterror() has the same behavior.
Guest (2)
Similar Topics
[Custom Functions plugin] cases SS6179 (Bugs & Problems)
by PompelmoTell 07/02/2017 19:14:23(UTC)
7 Pages«<567
