Offline HWDstorm
#1 Posted : 30 August 2021 06:12:42(UTC)
HWDstorm
United States
I'm a structural engineer and a new SMath user. I was pretty excited when I found the "Structural Shape Property Extractor". It is very useful for obtaining properties of most of the shapes in the AISC manual. However, for me, any shape with a period (.) or a forward slash (/) says "the shape does not exist". This takes our most "L" shapes and "HSS" shapes as well as others. I have emailed the programmer but have not received a response.
Is anyone else using this plugin and getting this error?
Are there other tools/solutions that engineers are using for getting shape properties?
Any help is appreciated.
Thank you
HWDstorm
Offline uni
#2 Posted : 31 August 2021 11:20:07(UTC)
uni
It is not clear which plugin you mean. This may not be a bug, but normal behavior. Unfortunately, not all plugins are supported by the authors and it will take a while to find out what is wrong.
Give a link to an example that doesn't work or attach it to your post.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline HWDstorm
#3 Posted : 31 August 2021 19:24:54(UTC)
HWDstorm
United States
Viacheslav,
Thank you for your reply.
The plugin is called "Structural Shape Property Extractor" in the plugins menu. It's listed as "AISC Shape Property Extractor" on the download page (link below). I'm including the pluging guide as well as a calc sheet with some of the examples I believe are not working properly.
AISC Shape Property Extractor Link
AISC Shape Property Extractor Guide.sm (30kb) downloaded 63 time(s).
Property Extratctor Examples.sm (9kb) downloaded 50 time(s).
Property Extratctor Examples.pdf (70kb) downloaded 69 time(s).
Thank you for your time.
Offline uni
#4 Posted : 01 September 2021 03:33:13(UTC)
uni
I have not found sources for this plugin. They are not contained in the version control system. I tried to decompile the plugin, but the source code is written in vb.net, which is difficult to recover. To fix it, you need to get the original sources. Otherwise, it is necessary to modify the result of decompilation in C#.
Russia ☭ forever
Offline HWDstorm
#5 Posted : 01 September 2021 13:27:45(UTC)
HWDstorm
United States
Thank you for looking into it for me. I was hoping that there was something I was doing wrong or it was an easy fix. I'm not familiar enough with programming to dive into it right now so I'll just have to live without it at the moment. Perhaps I'll try contacting the programmer once more.
Offline uni
#6 Posted : 01 September 2021 14:07:07(UTC)
uni
I asked Andrey to update the plugin. The source codes are not publicly available.
Russia ☭ forever
Offline Razonar
#7 Posted : 01 September 2021 23:00:11(UTC)
Razonar
Uruguay
Was thanked: 830 time(s) in 526 post(s)
Hi. The attached have the AISC table as SMath matrices and vectors.
AISC.sm (6,532kb) downloaded 60 time(s).
Edited by user 01 September 2021 23:08:30(UTC)  | Reason: Not specified
Offline HWDstorm
#8 Posted : 03 September 2021 03:40:52(UTC)
HWDstorm
United States
Thank you. This helps.
Offline Razonar
#9 Posted : 03 September 2021 08:59:09(UTC)
Razonar
Uruguay
Hi. Notice that to really replace the plugin with the above file, it would be convenient to make two changes: First, save only the collapsed areas with the data in a file, since using them directly in the document where the calculations are carried out would be very inefficient given the large size of the matrix with the data. Then add a vector with the units of each property. In this way, in the document where the structure calculations are carried out, the file with the data can be referenced with the include() function.
Offline Andrey Ivashov
#10 Posted : 16 December 2021 03:02:11(UTC)
Rank: Administration
Plug-in is fixed now.
on 16/12/2021(UTC)
