SMath Studio Forum
Questions
Levi-Civita Symbol via Programming functions
Joined: 26/09/2021(UTC) Posts: 66 Location: Adelaide Was thanked: 5 time(s) in 3 post(s)
I have a symbol that nearly works for all cases. At the moment I am not sure how to get the first IF statement to work. Levi-Civita Symbol_try.sm (96kb) downloaded 6 time(s).Thank you for your help in anticipation Kind Regards, John
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 833 time(s) in 527 post(s)
Hi. The "E" in the first if isn't the same "E" than the others. You can see that looking that the bakground isn't gray, like in all others. Best regards. Alvaro.
Originally Posted by: Razonar Hi. The "E" in the first if isn't the same "E" than the others. You can see that looking that the bakground isn't gray, like in all others. That fixed it Alvaro! ...
Joined: 12/03/2019(UTC) Posts: 19 Was thanked: 1 time(s) in 1 post(s)
Hi John, I did the same thing a few days ago, typing in a few less letters if you need it....
Originally Posted by: Jopi Hi John, I did the same thing a few days ago, typing in a few less letters if you need it.... Your solution is more efficient than mine Jopi, yes please post your code, thank you, Kind Regards, John
Levi-civita.sm (9kb) downloaded 18 time(s).Does anyone know how to summarize the result into a single vector? Best regards
Originally Posted by: Jopi Does anyone know how to summarize the result into a single vector? I don't understand much in there. As it looks your are solving Cross Product ... is it ? Cheers ... Jean Levi-civita [Not Sure].sm (13kb) downloaded 7 time(s).
Originally Posted by: Jean Giraud Originally Posted by: Jopi Does anyone know how to summarize the result into a single vector? I don't understand much in there. As it looks your are solving Cross Product ... is it ? Cheers ... Jean Levi-civita [Not Sure].sm (13kb) downloaded 7 time(s). Here is the cross product Jean and also Jopi, so you are pretty close to the money. and here is a bit more again, this time the determinant: Here is the wedge product i am particularly interested in, see the similarity to axb?
Originally Posted by: johnspark Here is the cross product Jean and also Jopi, so you are pretty close to the money. Thanks John ...more in there from lot more convivial Smath Shitting snow today, not to scare the bear ... Jean. Maths vminor [cofactors].sm (41kb) downloaded 6 time(s).
SMath Studio Forum
Questions
