DSP Library Functions list:
dspl_bessel_i0(-1) - (x) modified bessel function of the first kind I0(x). dspl_butter_ap(2) - (rp,ord) calculates the transfer function H(s) coefficients of analog normalized lowpass Butterworth filter. dspl_butter_ap_zp(2) - (ord,rp) calculates arrays of zeros and poles for analog normlized lowpass Batterworth filter transfer function H(s). dspl_cfft(1) - (x) calculated n-points FFT for the complex vector x. dspl_cgoertzel(2) - (x,ind) calculates samples of n-point DFT, according to ind indexes vector (Goertzel algorithm). dspl_cheby1_ap(2) - (rp,ord) calculates the transfer function H(s) coefficients of analog normalized lowpass Chebyshev type 1 filter. dspl_cheby1_ap_zp(2) - (ord,rp) calculates arrays of zeros and poles for analog normlized lowpass Chebyshev type 1 filter transfer function H(s). dspl_cheby2_ap(2) - (rs,ord) calculates the transfer function H(s) coefficients of analog normalized lowpass Chebyshev type 2 filter. dspl_cheby2_ap_zp(2) - (ord,rs) calculates arrays of zeros and poles for analog normlized lowpass Chebyshev type 2 filter transfer function H(s). dspl_cidft(1) - (x) calculates the n-point inverse discrete transform Fourier complex spectrum x. dspl_cifft(1) - (x) calculates n-point IFFT of complex data x. dspl_concat(2) - ( a,b ) concatenate arrays a and b. dspl_conv(2) - ( a,b ) convolves two complex vectors. dspl_decimate(2) - (x,d) decimates the real vector x by d times. dspl_cdft(1) - (x) calculates the n-point discrete Fourier transform complex signal x. dspl_dft(1) - (x) calculates the n-point discrete Fourier transform real signal x. dspl_ellip_ap(3) - (rp,rs,ord) calculates the transfer function H(s) coefficients of analog normalized lowpass elliptic filter. dspl_ellip_ap_zp(3) - (ord,rp,rs) calculates arrays of zeros and poles for analog normlized lowpass elliptic filter transfer function H(s). dspl_fcoeff(4) - (t,x,T,nw) calculates Fourier series coefficient for real vector x. dspl_fft(1) - (x) calculated n-points FFT for the real vector x. dspl_fft_mag(2) - (x,fs) calculates the frequency response for a real vector x. dspl_fft_mag(3) - (x,fs,flag) calculates the frequency response for a real vector x. dspl_fft_shift(1) - (x) perform a shift of the vector x, for use with the fft and ifft functions, in order to move the frequency 0 to the center. dspl_filter_freq_resp(5) - (b,a,ord,w,flag) calculates magnitude, phase response and group delay vectors for digital or analog filter. dspl_filter_iir(4) - (b,a,ord,s) calculates real IIR filter output for real signal s. dspl_fir_linphase(6) - (ord,w0,w1,ftype,wtype,wprm) calculates linear-phase FIR filter coefficients by window method. dspl_flipip(1) - (x) flips complex vector x in the memory. dspl_freqs(4) - (b,a,ord,w) calculates the values of the complex gain H(jw) of the analog filter. dspl_freqz(4) - (b,a,ord,w) calculates the values of the complex gain H(e^jw) of the digital filter. dspl_fseries(2) - (ws,t) reconstructs the time function from Fourier series coefficients. dspl_fseries(3) - (w,s,t) reconstructs the time function from Fourier series coefficients. dspl_goertzel(2) - (x,ind) calculates samples of n-point DFT, according to ind indexes vector (Goertzel algorithm). dspl_group_delay(5) - (b,a,ord,flag,w) calculates group delay for digital or analog filter. dspl_iir(6) - (rp,rs,ord,w0,w1,ftype) calculates the coefficients of the digital IIR filter transfer fucntion H(z). dspl_linspace(4) - (x0,x1,n,type) fills a vector with n linearly spaced elements between x0 and x1. dspl_logspace(4) - (x0,x1,n,type) fills a vector with n logarithmically spaced elements between 10^x0 and 10^x1. dspl_ones(1) - (n) returns vector filled by ones values. dspl_phase_delay(5) - (b,a,ord,flag,w) calculates phase delay for digital or analog filter. dspl_randb(1) - (n) generates a binary unipolar [0, 1] pseudo-random vector. dspl_randb2(1) - (n) generates a binary unipolar [-1, 1] pseudo-random vector. dspl_randi(3) - (n,start,stop) generates a pseudo-random vector of integers ranging from start to stop inclusive. dspl_randinit(2) - (type,seed) pseudorandom numbers generators initialization. dspl_randn(3) - (n,mu,sigma) generates a vector of normally distributed pseudo-random numbers. dspl_randu(1) - (n) generates a vector of uniformly distributed pseudo-random numbers in the range from 0 to 1. dspl_scale_lin(5) - (x,xmin,xmax,dx,h) vector x linear transformation. dspl_sum(1) - (x) returns the sum of the elements of a real vector x. dspl_sum_sqr(1) - (x) returns the sum of squares of the elements of a real vector x. dspl_window(2) - (n,wtype) calculates a periodic or symmetric window function. dspl_window(3) - (n,wtype,wprm) calculates a periodic or symmetric window function.
DSPL-2.0 — opensource cross-platform digital signal processing algorithm library, written in C language. Distributed under LGPL v3 license. This allows to use this library in all applications with dynamic linking. Source codes are available on GitHub. DSPL-2.0 includes follow algorithms sets: - Digital spectral analysis, discrete and fast Fourier transform algorithms.
- Analog and digital IIR filters design and analysis.
- Digital FIR filters design and analysis.
- Windows function collection includes 15 different parametric and nonparametric window functions.
- Digital Hilbert transform algorithms.
- Mathematical sections includes trigonometric, hyperbolic, elliptic functions of real and complex variables.
- Pseudorandom numbers generation algorithms.
- Statistic functions.
- Linar algebra algorithms (BLAS and LAPACK packages are used under the hood of the DSPL-2.0 library).
- Digital resampling algorithms.
Examples: dspl_filter_iir.pdf (156kb) downloaded 62 time(s). dspl_fir_linphase.pdf (247kb) downloaded 42 time(s). dspl_iir.pdf (234kb) downloaded 31 time(s). dspl_window.pdf (857kb) downloaded 47 time(s). Links: 1. DSPL-2.0 — free DSP algorithm library . Edited by user 12 December 2021 22:38:42(UTC)
