Hi, I ran into an issue trying to use Solve() function with Maxima plugin. I installed the last version of plugin (5.45.1) and even the refence book seems to not work properly: although, when I remove the L:= it does solve again. how could I resolve this issue? regards, Edited by moderator 24 December 2021 17:27:37(UTC)
| Reason: Made a preview for the images.
Joined: 28/08/2014(UTC) Posts: 1,360 Was thanked: 820 time(s) in 519 post(s)
Originally Posted by: FT_PENG ... how could I resolve this issue? regards, Hi. Think of Solve's non-evaluation problem as something similar to what you get with Hold in Mathematica or with 'x' in Maple. I do not know if it is a change in the behavior of the plugin that is here to stay, or an unwanted effect due to an update, but what you can do is not define with := and ask in the same line for the symbolic result, but first define L := Solve (...) and then symbolically evaluate L -> this means, SMath needs another step to proceed to evaluate the expression in Solve. Best regards. Alvaro.
From native Smath 6179.
Originally Posted by: Jean Giraud From native Smath 6179. Not related with OP's question. Your reply doesn't have the answer also.
