SMath Studio Forum
Bugs & Problems
[OpenSuse] symbols not showing properly on screen
Joined: 02/06/2022(UTC) Posts: 14 Was thanked: 1 time(s) in 1 post(s)
Hi, I don't know if someone has seen this before but I'm having problems with SMathStudio showing assign/evaluate (:=,=) and math operators (+,-) as shown below: does anyone have an idea of what is going on? I'm using OpenSuse, SMathStudio (Windows version with wine, but it also happens with the Mono version as well), latest stable/beta versions. It happens with new worksheets and with loaded worksheets. Best regards Edited by moderator 01 July 2022 13:45:55(UTC)
| Reason: marked as bug
Originally Posted by: overlord What I did was simply copying Courier New fonts from windows disc to my linux. Here all the Courier New files on my pc. The path for font files should be copied is /home/{USER}/.local/share/fonts/This has worked very well. At least how it is for me. Regards courier.zip (1,656kb) downloaded 45 time(s). May be a font issue. Try to download courier new font and copy to proper location mentioned above. Regards
Hi, I tried the courier font as well as other fonts and still it doesn't work. Also, the program crashes if I try to change the font family: I placed all font families in the folder mentioned before. Best regards,
Try to run with mono, not wine.
Same behavior, with mono:
Originally Posted by: charlamb Same behavior, with mono: I still see wine symbol at titlebar of error message. Please make sure you have installed mono package installed. And could you please check your inbox? I will try to continue to help you from there. Regards
I have tried Smath with openSUSE_leap_15.4_live iso. Seems everything is fine and working as it should be. At first I tried with appimage I created. It is v0.99.7822 and it worked flawless. Then I have installed mono-complete and downloaded latest v1.0.8206. And there was no issue with it either, no problem with symbols or anything else. Can't help you further from here without additional information. Regards
SMath Studio Forum
Bugs & Problems
