I was stuck in a ragged moment. I don't know how to draw a graph. Finally, a correct chart made in Excel. 248. proba do wyslania.sm (24kb) downloaded 12 time(s).
Originally Posted by: mareksss I was stuck in a ragged moment. I don't know how to draw a graph. Finally, a correct chart made in Excel. You didn't define a, P, P.o, P.r, D.k. After them defined with a number, a graph can appear. Regards
Sorry I didn't save before posting. That's right now. I have problems with ]the Mg1 (x) and Mg2 (x) graph, this one at the end. proba do wyslania.sm (51kb) downloaded 11 time(s).
Originally Posted by: mareksss I have problems with ]the Mg1 (x) and Mg2 (x) graph, this one at the end. If I understood correctly, you are trying to plot graph picture in your file. Here it is, you can download and check it from file below. Regards proba do wyslania.sm (47kb) downloaded 6 time(s).
Actually you don't need stack, augment, vectorize, etc. It can also be plotted easily like this. Regards proba do wyslania.sm (46kb) downloaded 10 time(s).
