As I see, we can use Matlab Runtime instead of current solution. Using it, we can get a 64-bit version of the plugin. |
Plugin updated. Only the 32-bit version is available. Changes: - plugin renamed to Matlab Runtime Library; - converting the task for the ODE solvers to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed; - totally refactored. Edited by user 10 January 2022 12:11:13(UTC)
Joined: 07/12/2018(UTC) Posts: 44 Was thanked: 1 time(s) in 1 post(s)
Dear Viacheslav, thank you for the plugin. Can I ask a quick question? Does it work only with the older version? By me, unfortunately, this plugin is not accessible. Best regards, Andrey
Originally Posted by: andrbig77 Does it work only with the older version? By me, unfortunately, this plugin is not accessible. You need to switch the program to 32-bit mode. This is an old library and didn't exist at that time in 64-bit form. That is why I additionally pointed it out. You must manually change the bitness of the executable file in administrator mode. After that, the library will become available. CorFlags will help you to use this plugin on 64-bit system. 32-bit ON: CorFlags /32bit+ Solver.exe or CorFlags /32bit+ SMathStudio_Desktop.exe32-bit OFF: CorFlags /32bit- Solver.exe or CorFlags /32bit- SMathStudio_Desktop.exe CorFlags.zip (142kb) downloaded 11 time(s).Edited by user 10 January 2022 11:55:34(UTC)
3 users thanked uni for this useful post.
on 11/01/2022(UTC), on 11/01/2022(UTC), on 14/10/2022(UTC)
Hallo Viacheslav,
thnak you for your help and your quick reply!
Joined: 10/12/2009(UTC) Posts: 249 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Originally Posted by: uni As I see, we can use Matlab Runtime instead of current solution. Using it, we can get a 64-bit version of the plugin. Hi, Any news of using this runtime on 64 bits version?
It differs in structure and I can't find examples of how to use it separately from matlab. In addition, the size of the distribution is much larger. I will have to start all over again for the new version of matlab engine. |
