6 Pages«<456
Offline Alex M.
#101 Posted : 14 November 2022 21:33:11(UTC)
Alex M.
I will likely be cleaning up the functionality of the plugin in next couple months.
Are there any requests for the image region plugin? Given it is one of the most popular SMath plugins I am pleased to see no comments over the past 5 years.
Image Region - done right the first time!
thanks 2 users thanked Alex M. for this useful post.
on 14/11/2022(UTC),  on 16/11/2022(UTC)
#102 Posted : 15 November 2022 01:41:05(UTC)
From recollection, there was a request for a pasted image
to be associated with a description ... likely not honored.
Offline Razonar
#103 Posted : 15 November 2022 09:07:37(UTC)
Razonar
Uruguay
Was thanked: 818 time(s) in 518 post(s)
Hi Alex. You are right. Great job. It would be used a more recent version of the SVG' DLL in your plugin and you may see if you can implement some of the commands to draw on SVG (like here) or pixel by pixel (like here).
#104 Posted : 16 November 2022 00:24:54(UTC)
There are some issues in the bug tracking system related to image region. Yet I didn't check if they still are valid.
#105 Posted : 31 January 2024 02:34:39(UTC)
I experience loss of temp files of image regions in case of multiple instances of SMath. When copying objects or when trying to save the file, error messages pop up that some temp files aren't found.
My suspicion is that the image region doesn't cleanly separates temp data for individual instances and cleanup might be overgreedy.
This recently has lead to loss of contents in my work. For use with Maxima Draw commands this is less of an issue, because the images are generated dynamically and do not depend on storage by the image region.
#106 Posted : 02 February 2024 04:15:30(UTC)
As it looks, Image Solver 30405 does not works same as SS 6179.
If I want to close an image in session I can't.
It reports "Please wait current operation to finish"
Up until now, I have been able to doctor only one Image.
I suspect Solver 30405 does not auto-save within itself like SS 6179.
If so ... a damned bug !
Guest (2)
6 Pages«<456
