Hello!
Brand new to SMath, and I was curious to know if there was a way to simulate creating objects with properties etc. For example, I have a car object that has a speed it's moving at and its weight.
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 833 time(s) in 527 post(s)
Hi. Something like this? obj_set_get.sm (12kb) downloaded 35 time(s).Best regards Alvaro.
on 19/01/2023(UTC), on 20/01/2023(UTC)
Hey Alvaro, that is really cool, I didn't know you could do that in SMath. Thank you
Hey Alvaro, I was testing out your methods with the inclusion of loops and it seems that I can't create a variable beforehand and assign it, it has to be empty. Do you know a way around this? This is ultimately what I am trying to do with these functions, where I can get a mutable array of "Zones", each with their own properties (ie. area, x/y location etc.) For reference I read through this thread as well: https://en.smath.com/for...iable-Name--str2var.aspxand tried some of the solutions posted on there but to no avail.
I figured it out, just don't know a way around it. Since I'm calling str2num(output_i), it's giving me the value of that expression and not the variable itself.
Originally Posted by: alisin I figured it out, just don't know a way around it. Since I'm calling str2num(output_i), it's giving me the value of that expression and not the variable itself. Yep. You need to call str2num at the worksheet level. Something like this obj_set_get.sm (19kb) downloaded 6 time(s).Also, I'm go to modify the code for accept set or collections. Best regards. Alvaro.
Jean's reply is not corresponding with question.
This algorithm is not creating an object. It is only finding index of a key in data.
2 users thanked overlord for this useful post.
on 20/01/2023(UTC), on 20/01/2023(UTC)
Originally Posted by: overlord Jean's reply is not corresponding with question. Thanks. Updated. obj_set_get V2.sm (47kb) downloaded 21 time(s). obj_set_get V2.pdf (155kb) downloaded 13 time(s).Best regards. Alvaro.
Originally Posted by: Razonar Originally Posted by: overlord Jean's reply is not corresponding with question. Thanks. Updated. obj_set_get V2.sm (47kb) downloaded 21 time(s). obj_set_get V2.pdf (155kb) downloaded 13 time(s).Best regards. Alvaro. This is incredible work, it would be really cool to see this kind of feature built-in to SMath in the future.
This algorithm is not creating an object. It is only finding index of a key in data. mod: Deleted since it was off-topic.
@Jean: please stay on topic. |
Originally Posted by: Razonar Originally Posted by: overlord Jean's reply is not corresponding with question. Thanks. Updated. obj_set_get V2.sm (47kb) downloaded 21 time(s). obj_set_get V2.pdf (155kb) downloaded 13 time(s).Best regards. Alvaro. I"ve been absolutely loving using this! Is there a way to disable the historical value saving? I'm trying to override some values rather than keep a record of them, I was thinking of going through a loop that check to see if the second column is zero and making a new submatrix without that row and calling it recursively until there are no 0 values left, however that presents a future problem when the value I want to set is 0. Is there a way around this?
Originally Posted by: alisin ... Is there a way to disable the historical value saving? ... Hi. A version without values history. obj_set_get V3.sm (54kb) downloaded 16 time(s).Best regards. Alvaro.
Maybe this plugin will be useful: Wiz FunctionsIt contains a set of functions for manipulating key and value pairs. |
