Originally Posted by: overlord Result can not be parsed through plugin Check for more, but not possible to exhaust. Maple Sanity.sm (61kb) downloaded 54 time(s).
Originally Posted by: overlord It works now but with a small issue. Tried with both optimizations but cannot jump over this issue. Result can not be parsed through plugin if nthroot is nested. When it is written as power it can be calculated however. I need to rewrite part of the function for this. I can't fix it quickly yet. |
Originally Posted by: uni I need to rewrite part of the function for this. I can't fix it quickly yet.
Doesn't matter when as long as it is fixed. Well, if you say I won't fix ever or any time soon I respect that too. Thanks. Edited by user 07 March 2021 12:51:07(UTC)
A simple function to correct maple plugin result matrix. Regards maplecorrect.sm (27kb) downloaded 72 time(s).
2 users thanked overlord for this useful post.
on 03/03/2022(UTC), on 22/03/2022(UTC)
Plugin updated. Changes: - maple() returns the string as is without conversion; - refactored. maple-system.sm (10kb) downloaded 24 time(s). |
More simple. Regions with a red border still work. maple-system-2.sm (9kb) downloaded 11 time(s). |
Joined: 28/08/2014(UTC) Posts: 1,366 Was thanked: 825 time(s) in 523 post(s)
Originally Posted by: uni More simple. ... An small variation. maple-system-4'.sm (12kb) downloaded 14 time(s).Best regards. Alvaro.
Small restrictions. All curly braces are converted. This is necessary for the maple() function to work. I'll see if it's possible to make an exception for strings. maple-system-5.sm (13kb) downloaded 12 time(s). |
Joined: 27/03/2019(UTC) Posts: 75 Location: coah Was thanked: 27 time(s) in 22 post(s)
I only get this...may be problems with the permission? if i change de path... some advices? Edited by moderator 24 April 2023 15:31:31(UTC)
The path "D:\Temp" must exists. |
I hope you can solve the problem with the {} for now this format works for combined text and number output.
Originally Posted by: uni The path "D:\Temp" must exists. yes, this work very well, thanks!
Plugin updated. Changes: - added support for SMath variables; - curly brackets in strings are not replaced. maple-system-5.sm (14kb) downloaded 18 time(s).Edited by user 27 April 2023 09:07:54(UTC)
Originally Posted by: uni More simple ... But powerful. For install SymPy on windows can use " pip install sympy" or " conda install sympy" in a DOS shell window. Best regards. Alvaro.
Same for R. You can install it using scoop: scoop install R maple-system-R.sm (9kb) downloaded 8 time(s). |
Hi uni, Me again complaining about Linux. After changing file paths according to linux, your new features can create test.py and out.txt. But out.txt is empty. Changing python command to /usr/bin/python didn't work either. If there is a trick to make it work under linux, it would be useful.
