SMath Studio Forum
Questions
"Operation cannot be performed with units" for exponential function
Hi, I get the "Operation cannot be performed with units" error for a complicated equation involving exponential functions which seem to be the culprit: Here's the file: Operation units.sm (18kb) downloaded 8 time(s).Is there a mistake in this equation in SMath ? Here's what it looks like in the original:
The main error you made is in obtaining the pulsation from the frequency. Also in the formulation of X5 there were two or three errors of evaluation of the SIN (or cos) of the pulsation multiplied by a time (attention to the use of parenthesis) Operation_units.sm (18kb) downloaded 11 time(s).sergio
Thank you very much. The formula for ω_n from the book did look suspicious to me so I tried removing f_n from it but it didn't help so I thought that the main problem lies somewhere else.
How can I plot the result as x(t) for t=0 to t=12 s ? From what I remember, plots require x as a variable so I tried with u(x) but I still can't make it work even with all the occurrences of t replaced with x (although I'd rather avoid doing that): Operation units fixed with plot.sm (17kb) downloaded 8 time(s).
You have to manage the variable [x] and the result [f(x)] units Edited by user 26 June 2023 18:07:53(UTC)
SMath Studio Forum
Questions
