#1 Posted : 09 August 2023 14:45:57(UTC)
The 2D plot exhibits a problem in build 8348, which didn't appear in previous versions. In 7561 it works, however, the attached file can't be opened, you have to copy/paste the content)
In more recent versions I experienced crashes related to the extension manager (online gallery). This is perhaps due to ongoing re-structuring of the website.
The problem:
The built-in 2D plot can't plot f(x), D and the integral of f(x) at the same time. f(x) and D work, f(x) and integral work but not all three at once.
The X-Y plot plugin can handle all three at once, yet you have to make sure that the dummy variable in the integral isn't taken as undefined.
Perhaps wrapping eval() around random subexpressions or modifying all or some of the involved definitions by line operator could provide a work-around, yet I consider the problem being a bug or at least a change to the worse.
plot interp.sm (12kb) downloaded 11 time(s).
#2 Posted : 09 August 2023 20:02:49(UTC)
Commonly encountered from NON-NATIVE functions.
Isolate 'D' ... add as argument plot QuickPlot
Same Studio versions and Solver 30405.
Offline overlord
#3 Posted : 09 August 2023 22:29:21(UTC)
Turkey
Maybe the problem is with string plotting.
It can't get dots plot if used in a variable.
When copy pasted, it can however.
on 10/08/2023(UTC)
#4 Posted : 09 August 2023 23:33:23(UTC)
Alternately, plot f(x) & the XY augmented data points,
XY as plotting argument instead of the expansion.
Next, discretize f(x) and add the FD cumulative on the plot.
At this point you have the 3 on same 2D Quick Plot.
FD [Finite Differences] is exceptionally accurate,
often used as a yardstick sanity check.
In your example, FD & Simpson agree to 6 decimals.
Cheers ... Jean.
#5 Posted : 09 August 2023 23:44:50(UTC)
This is perhaps another similar problem but not the same one. In my example, the right plot shows that string plotting from a variable isn't an issue in general.
The problem comes if combined with the integral.
BTW the behaviour doesn't change when I replace D everywhere by the expression.
Another BTW: I don't think you need to vectorize the augment operation.
Offline Razonar
#6 Posted : 10 August 2023 00:59:22(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
... The problem comes if combined with the integral.
Hi Martin. You can add if() to the list. Usually, if something is wrong with int, it is also wrong with if and vice versa.
on 10/08/2023(UTC)
#7 Posted : 10 August 2023 01:46:14(UTC)
Yes, the behaviour is indeed similar. if() and f(x) work but not if(), f(x) and a matrix.
Again the X-Y plot proves to be more robust.
I was going to file a bug report, yet I found that there is already a related bug, filed 9 years ago: SS-41.
The original report was with the Gamma function. Either it is because Gamma uses if() or it is another instance of the bug.
plot interp.sm (18kb) downloaded 4 time(s).
#8 Posted : 10 August 2023 02:16:03(UTC)
... alternately.
discretize Simpson ... Bingo 3 plots on same Quick Plot
Offline overlord
#9 Posted : 10 August 2023 03:41:58(UTC)
Turkey
I didn't need, but I did to show even individual strings doesn't plot.
Here you can see another fail even with a single string variable.
Offline Razonar
#10 Posted : 10 August 2023 04:13:53(UTC)
Razonar
Uruguay
Hi. The workaround. It also solve the roots issue with int() and if()!.
plot interp.sm (21kb) downloaded 12 time(s).
Edited by user 10 August 2023 04:42:11(UTC)  | Reason: Not specified
#11 Posted : 10 August 2023 11:24:14(UTC)
May this be a hint for eventual improvement of the plot region.
