Offline Basile
#1 Posted : 27 October 2012 04:49:20(UTC)
Basile
I think that SMath is mature enough at this point to require an alternative plotting approach.
Although the current approach is innovative, engineering applications require axes that are lin-lin, log-lin, or log-log. In addition there is need for the user to have full control of minimum and maximum values of the axes, legend, various types of plots etc. SMath will be great tool in preparing graphs for publication.
I hope this option will become available for the benefit of the SMath community.
Thank you,
Basile
Similar Topics
Ranges, Array, and Plotting (Questions)
by GFDIntano 19/12/2023 23:20:14(UTC)
Issue plotting function with units (Questions)
by tedd 08/09/2023 19:29:14(UTC)
An error by Diagram plotting (Questions)
by OchkovVF 01/09/2023 11:06:09(UTC)
Problem Plotting Functions (Questions)
by JReg 08/07/2023 08:43:26(UTC)
Plotting a x,y graph with complex numbers (Questions)
by Lee Snook 06/07/2023 22:42:28(UTC)
Variable plotting (Questions)
by JJJC 23/04/2023 14:06:08(UTC)
Functions not Plotting in Graph (Questions)
by Albedo 09/10/2022 06:06:17(UTC)
plotting circle does not work (Questions)
by Blackbambi 13/03/2022 16:52:33(UTC)
Plotting complex functions (Samples)
by Razonar 04/12/2021 08:43:26(UTC)
Animated Planetary Orbital Plotting (Samples)
by overlord 05/11/2021 08:50:28(UTC)
Plotting with a step (Questions)
by Patukott 21/10/2021 13:28:01(UTC)
Plotting strings (Feature Requests)
by hanskl 26/05/2021 02:10:14(UTC)
Plotting with 2D plot (Bugs & Problems)
by Tommy Svartvatn 14/01/2021 16:36:02(UTC)
IF function and plotting a function (Questions)
by davidlimtw 12/01/2021 23:11:18(UTC)
Complex Plotting in Smath (Questions)
by BridgeNut 13/05/2020 22:26:48(UTC)
